Question about Dayton Water Heaters
No heat from water heater, wish to replace thermastat and heating elemnt, need part numbers please
  • 30 Answers
Thermostats and elements are fairly common items from home improvement stores. remove the old ones and take with you, a representitive can cross reference them for you. Just make sure the elements are of the same voltage and wattage rating
Posted on Aug 25, 2010
Water not getting hot in electric mode...heating element has been replaced, did not solve the problem.
Check switch and timer working ok also pencil Thermostat in side heating elemnt is ok and is turned up enough to call 4 heat
Sep 16, 2013 | Suburban Gas and Electric Water Heater, 12...
Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
I have an electric 50 gallon hot water heater 2 years old its seemed to be leaking by the upper heating element. I replaced the elment and it still leaks what could be the problem
It could leak trough the bolts that holds the element, the gasket as well, and it could be a crack in the tank around the opening of the element if it's a plate type element, if it's a screw in type elemnt, than it could be a crack in the threads or you didn't seal the threads with proper compound...
Aug 02, 2011 | Water Heaters
My water heater is overheating, my pipes are getting very hot. my relief valve goes off every 5 to 10 mins. do i have a thermastat probelm or do i have heating coil problem. please help. thnx for...
Could be thermostat sticking, Make sure back of thermostat makes good contact with tank, or if it has a temp probe make sure it in contact with tank. Also you can try to change setting on thermostat down 5 deg. to see if that works.
Dec 20, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Need to relight Rheem hwh. Have not seen unit, but believe it is electric.
electric heaters dont need to be light because they dont use gas, the power is off to the heater or the thermastat is bad or the heating element is bad. call the manufacture and get free customer service and support over the phone.
Apr 27, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Heating circuit getting hot when hot water is running
Check to see if diverter valve is in domestic mode or heating mode.
Jul 04, 2009 | Water Heaters
Water heater not heating it's a richmond water heater
Now change the thermostats........this is the only other thing it could possibly be.
Apr 27, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
WATER IS NOT HOT
Check the thermastat, located in removable panel. warning dont set above 120- 130. If not the case it could be a bad heating coil. Easy to change in electric just googl a how to sitr. If your not Real Handy with Your Handa I would recomend calling a plumber to check heating element, Could be cheaper to replace
Jan 03, 2009 | Rheem 81VP15S Point-of-Use Electric Water...
Water Heaters Logo
61 people viewed this question
Top Dayton Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Dayton Water Heater Expert? Answer questions, earn points and help others
