Question about KitchenAid Dishwashers
Door drops down hard when opened - KitchenAid Dishwashers
  • KitchenAid Master
  • 2,605 Answers
Hello, Welcome to FixYa.
Unfortunately this is actually very common. Based on your description, either one or both of the door spring linkage`s has broken.
The good news though...It is a fairly minor procedure to replace it/them.
First, slide the entire unit out from the cabinet a couple or three inches and you`ll see the plastic roller assembly and rope ( except yours is likely broke...at least one by the sounds of your description ) attached to the side.
**You`ll need to insure your connections will allow you to pull the unit out however, otherwise they - water, power, drain hose - must be disconnected to prevent any damage.**
If you have any reservation to performing this repair on your own please call in a qualified appliance technician.
The parts ( # 1059756 @ repairclinic ) come in a kit as I alluded to and will look like what I attached below...
These are available at most brick & mortar appliance part locations or on-line vendors such as "repairclinic.com" "searspartsdirect.com" or "apwagner.com" to name a few.
They range in price for around $20, or you can just purchase the rope/link seperately for about $4 part # 1159210 @ repairclinic.
I recommend replacing the entire kit and checking the spring itself, if it looks ok and not stretched or broke it is likely ok...they are seperate from the kit ( # 830967 door spring @ repairclinic as well )
Hope that helps move you forward. Thank you for visiting "fixya" today.
Please take a moment and rate the solution provided here or a testimonial if you feel warranted.
Let me know if you require further assistance and good luck.
macmarkus :)
Posted on Aug 25, 2010
My driver side door of my 2005 dodge 3500 seems to
There are little device that are on the hinge of the doors , their purpose is to assist with closing the door. Sometimes they will wear out. They can be replaced though.
Oct 12, 2014 | Dodge Ram 3500 Cars & Trucks
My driver door in ny 71 squareback is stuck and I cannot open it
even with the key back and forth till the latch unlocks the spring is broken in the latch causing it to stay locked or try and take off the inner door panel i know its hard then you can unlock the latch from inside other than that just keep trying up and down with the door lock till it lets go and you can open it or drop down the window and try a rod down inside where the door lock is on the outside near door handle and push and pull the latch till it lets go
Jun 17, 2014 | Cars & Trucks
Front loader hard to latch, door drops down when opened, should I replace hinge?
Yes, maybe. The hinge may just be loose though. Hopefully, the screws holding it in place have not worn out the threads. Is there a lot of downward pressure being applied to the door.
Feb 06, 2013 | Frigidaire ATF6000ES Front Load Washer
We have a built in diswasher MDBH969 AWQ which is less than 2 years old. Suddenly the Door to the washer drops down quickly rather than what appeard to be spring loaded and would drop slowly before.
Bbeldenjr, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Bbeldenjr), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 23, 2017 | Whirlpool MDBH969AWS Builtin Dishwasher
Mustang drop down windows to clear roof moulding don't work. any suggestions?
i have a 2004 mustang v6, my windows do not drop when you pull the handle to open the door, and they clear the top just fine. i don't know where you hear they do, i would like to know.
Feb 09, 2012 | 2004 Ford Mustang V6
Door won't close and door does not lower without dropping out of control.
One or both of the door springs have broken causeing the door to drop.You haven't mention the brand or model so it's hard to help.The door not closeing could be because the door dropped open & is distorted or the door might be hitting a basket if the basket has been put in back to front.
May 30, 2010 | Dishwashers
Garage door repeatedly drops after opening.
Remove the cover from the motor unit and check the drive gear.
Jan 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a KitchenAid dishwasher. The door drops
either the door springs are broke,worn out or possibly the door balancers need replacing
Jan 10, 2010 | Dishwashers
Window doesn't drop down for door to open on 911 Cab
there should be a sensor on the door handel, so the minute you start pulling the body controll module drops the window through the regulator. an actuator unlocks and locks the door.
May 27, 2009 | 2001 Porsche 911 Carrera
Dishwashers Logo
41 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
