Question about Whirlpool AWZ410 Front Load Washer/Dryer
Door of washing machine is closed,way to open it?
I tried mannually but to no avail.
  • 487 Answers
Unplug the machine from the outlet and let stand for 20-30 minutes.
should open
Posted on May 13, 2008
Why won't washing machine start?
It is most probably the door sensor that is faulty. If the sensor does not sense the door closing the machine will stay in "open door" mode and will not start with it's program.
If the machine is still under warranty, take it in for repair or have someone check it out for you. It should be a quick fix, if parts are available.
May 24, 2014 | Washing Machines
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
My washing machine says door opened even i closed the door it' always says opened
Sounds like a sticky or broken lid switch. Over time, detergent and dirt can settle in and around the switch, causing it to stick or disabling it altogether. Try pushing the switch in manually to see if the door open warning goes out.
Oct 31, 2011 | Whirlpool Washing Machines
Miele Novotronic W 832 washer won't turn on. It suddenly turned off after trying to open the door and now it won't turn back on. I tried switchinging powersources, didn't work.
Make sure the door is properly closed!!! The door opener is electric, and the electrics are turned off unless the door is properly closed, hence with the door closed but not fully "home" you will neither be able to re-open the door nor wash what is in the machine. Just give the door a firm push closed and it should spring to life.
Apr 27, 2011 | Miele Novotronic Premier 500 Front Load...
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a samsung wf316law\xaa washer.I started a load of clothes and went out later and it had stopped early in first few cycles.I got the door open by pulling real hard took clothes to finish them.Now the...
hello,
solution bellow.
There is disclosed a method of controlling an automatic door opening/closing apparatus
for a washing machine that includes the steps of determining whether or not there is an error in
an automatic door opening or closing operation carried out in response to a command to open or
close the washing machine's door; determining if the erroneous operation has been
repeated more than a predetermined number of times according to consecutive incoming commands to open or close the door; and when erroneous operation has repeated more than the predetermined number of times, ignoring a subsequent command to open or close the door.
1. A method of controlling an automatic door opening/closing apparatus for a washing machine door, the method comprising the steps of: determining whether or not there is an error in an automatic door opening or closing operation which operation is carried out in response to a command to open or close the washing machine door;
determining if the erroneous operation is repeated more than a predetermined number of times according to consecutive incoming commands to open or close the washing machine door; and
in the event that the erroneous operation is repeated more than the predetermined number of times, ignoring a subsequent command to open or close the washing machine door.
2. A method as set forth in claim 1, further comprising the step of: returning the door to the washing machine to an original position in the event that the error occurs.
3. A method as set forth in claim 1, wherein the step of determining if there is an error in an automatic door opening or closing operation is performed on the basis of whether or not an inversion occurs in an open/closed state of the door within a prescribed period of time after an automatic door opening or closing operation is initiated.
4. A method as set forth in claim 1, further comprising the step of: clearing the number of errors in the case where the door of the washing machine has been opened or closed manually at the time of occurrence of the errors.
5. A method as set forth in claim 1, wherein said predetermined number is 3.
6. A method for controlling the operation of an automatic door mechanism in a washing machine, said method comprising the steps of: sensing a command to automatically open or close a washing machine door;
sensing whether a failure occurs in opening or closing the door in response to the command to automatically open or close the door;
incrementing a counter indicating the failure;
determining whether the counter is equal to a predetermined number; and
failing to engage the automatic door mechanism in response to a subsequent a command to automatically open or close the door if the counter exceeds the predetermined number.
7. The method claimed in claim 6, further comprising the step of: returning the door to an original position if a failure is detected.
8. The method claimed in claim 6, wherein failure is indicated by a lack of a transition between a door open state and a door closed state within a predetermined time period following entry of the command to automatically open or close the door.
9. The method claimed in claim 6, further comprising the step of: clearing the counter if the door is opened or closed manually following a failure indication.
Thanks for using fixya.
Nov 02, 2010 | Samsung Washing Machines
I have a front load lg washer. When I try to start a cycle I get an error code dE which according to the mannual is door error. I have closed the door tight and even held it closed but I still get this...
What has happened is either the Door Sensor or the input to that, has failed in some way... You will probably have to get it serviced, ask for a firm "Quote" from a reputable service man.
Feb 01, 2010 | Washing Machines
Machine doesn't recognize door is closed
Open the door, and look closely at any little plastic latches to see if a small part hasn't busted off.
They usually have plastic prongs that tell a small switch inside the hole it goes into, that the door is shut. It's a toughie.
I'd google around for it. Use the talking marks " ". Like google something like "Ultima 1000" space "door won't close" or 'dryer' 'door won't close'.
That will bring up dozens of other people who've asked questions to OTHER sites.
Tried holding it shut? DOes it work when you stand there? You could tape it with gaffer tape.
Methinks, its a latch problem, something's busted off.
Feb 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
2004 model - locks jammed
It sounds like the latch on your door is in the closed position. to fix this, first make sure that the door is unlocked, then pull on the door handle( as if you are trying to open the door) then at the same time using your finger or a pencil open the latch on the door. (try closing the door)
Sep 18, 2008 | 2007 Volvo C70
Door problem
use little bit force using screwdriver at the tip of door.u just calm urself & read the mannual carefully and systematically,ur lifepartner/family member company would make this job much handy.
Mar 22, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool AWZ410 Front Load Washer/Dryer Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal De
