Question about Samsung Televison & Video
Need instruction manual for a cctv samsung, shr 1040K 160 gb hdd digital video recorder, 4ch real time dvr. also a switcher to change channels, I just made a purchase from Sams Club and they did not have any instructions in the box for the 4 camers and recorder, please advise on how i can obtain the items. Thanks ppiinccorp@aol.com John Potempa 630/980/9805
Use this link at the samsung website and download the pdf file
http://samsungsecurity.com/product/p_manual_download.asp?seq=78&sel_seq=78
Posted on Feb 01, 2009
Can i connect to my laptop with that cctv view where i can see all camera on same screen?
you will need a multiplexer to connect all your cameras into and out to laptop on the front of the multiplexer you can use the buttons to see one or all the cameras you have installed.
May 24, 2014 | Astak Wireless 2.4ghz Night Vision Color...
" disfunction hdd pri"
Needs a new hard drive...Geek Squad could do it
Mar 17, 2014 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Certain cameras are showing the same video.
First you need to isolate the problem. Step one - make sure the video from the cameras is correct - use a monitor and check each input separate. If the video is correct, use one camera and start from input one on the DVR and check all inputs - in other words plug your camera in input 1, check for video to make sure is correct and shows up in the right place, than go to input 2. This way you check your DVR cards. If the video shows up, but in the wrong place - check the settings on the DVR - you might be able to change the physical input in the viewer.Or you might have a bad DVR.......do a search for DVR Doctors in Google - in case you need repair.
Jan 27, 2012 | Avermedia AVerDiGi SA6832E RACK 32-Channel...
Is this dvr capable of recording OTA TV?
The SHR-2082 cannot record OTA TV because it does not have a tuner. It is meant to record video from a set of security cameras.
The manual for the SHR-2082 is available from Samsung support here: http://www.samsung.com/us/support/downloads/SHR-2082 .
I wish that I had better news for you.
Jun 17, 2011 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
I have recorded footage from 9channel samsung DVR
Normally the recordings are in MP4 format and a lot of players cannot play it. You would need divx plus player. Its free.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 19, 2010 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Starts recording then stops
The manual says that it can be replaced with almost any standard IDE drive but mine has a Seagate 160GB drive in it so may want to stick with original equipment. Other than tha, any drive SHOULD work.
Jul 02, 2008 | Samsung 4 Channel Dvr
Samsung shr 1040 4 channel dvr
Try this it will work:
Press and hold "ch1 and mode" buttons at the same time and hold for about 45 sec. This will change yoursetting to VGA . You can fined this info in your user manual on page # 6-13 see note at bottom of page for "HIDDEN KEY" shortcut's
It's a good system dont give up.
Aug 17, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Televison & Video Logo
175 people viewed this question
Henry  Thomas
Henry Thomas
