Question about Frigidaire FAP094P1Z Portable Air Conditioner
Is coming a lot of water out of it - Frigidaire FAP094P1Z Portable Air Conditioner
I have a lot water coming from behind the tension belt pulley
sounds like you have a water pump issue. the pumps are designed to leak when they are going bad. check and see if the water is coming out of a small hole on the front of the water pump.
Aug 23, 2015 | Cars & Trucks
Slow fill of tank after flush
Why do say a lot of waste? Is not the water going into the tank. Is the water slow coming into the tank? Sounds like the valve letting the water in is blocked with sediment thus keeping the water from coming in. You may just need a new float assembly
Mar 28, 2013 | Home
The water that is spitting out when I press the steam button is clear and boiling hot. A LOT of water comes out.
Check to see the amount of water the iron requires. If too much is added it will spit water out can also come out of where the water goes in plus the holes the steam should come out. In order for the iron to steam the water must boil inside the iron. Check the instructions and see how mmuch the manufacturer suggests. You may have to fill it several times while doing the ironing. If there is no instruction try consulting the manufacturers web site for information on your make and model of iron. They should have instruction manuals available for download. If that is not the problem it could be cracked on the inside. Give the water adjustment a try first though a lot cheaper in the long run.
Aug 06, 2012 | Irons
I think water pump went out, but before all that work was to be done I noticed that I put water in the radiator and once I start the car water comes out from the water pump nipple and alot of water comes...
No it is not a cracked head, your water pump has a pressure hole to give you an indication that the pump is getting there. when the motor is running the pressure builds up and squirts the water all over, resulting in misleading you.
Sep 09, 2010 | 1993 Chrysler Lebaron
Warm water is coming out of new refrigator water
Is there a coil of tubing inside the refrigerator? This is how they usually cool the water. If you use a lot of water through the dispenser, the water will become warm.
I hope that this helps.
Tim
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in fridge coming from freezer
the drain line in the frezzer is blocked
Jun 09, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
A lot of vapor comes out htrough the repirator from the water tan
I think you mean 'radiator' and if you do, you probably have a leaking core or tank although it could be something as simple as a pressure cap that isn't screwed on correctly.
Once it starts, you need to stick your head under the hood (open it carefully, you might get a face full of steam or hot water) and search for the source of the leak.
Feb 19, 2009 | 2002 Chevrolet Malibu
Kenmore quietpak2 no longer rinse, drain, spin
Sounds like the pump, eighter blocked or needs new pump.Place outlet hose in to bucket to drain, if no water comes out its blocked, if water flows freely possible needs new pump.
Slim jim1
Nov 19, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Frigidaire FAP094P1Z Portable Air Conditioner Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
