Question about Kitchen Ranges
Water is connected, but will not go through the machine. when button is pushed, nothen comes out.
  • Kitchen Ranges Master
  • 4,924 Answers
If ti has power ..but the washing cycle do not wants to start ..check the locking mechanism ...cause it is probably jammed and this is the cause the the cycle do not starts..Try to jiggle the locking device parts ... spray it with a solution for to remove any deposits..and lubricate it ..
The idea is that in any washing cycle the door lock is the first operation in the cycle ..and if this can not be done ..the rest will not go on ..
Posted on Aug 25, 2010
Cold water not coming in the washer, only hot
Does the cold water actually flow from the tap when you turn it on? Sometimes plumbers mess up. Otherwise, you've probably got a bad switch, or possibly a bad timer.
Dec 31, 2014 | Washing Machines
It busses when the water if supposed to come out.
The cable may be kinked when you pushed it back
May 13, 2014 | Coffee Makers & Espresso Machines
I have a problem with a samsung wahing machine model WA95V3. No power coming on water solenoid valve when you switch on the push button,No error coming ,all the function is on.
you will find the solenoid is probably faulty and shorted out that part of the module, cheapest fix is to swap the hoses over at the taps and then select hot wash and cold water will come through the hot solenoid
Mar 08, 2014 | Samsung Wa95v3 7.5kg Washing Machine For...
We are attempting to use the LA3 by pouring water into the top of the machine as opposed to auto through a water line. The water heats up, the green ready light comes on, I push the start button and it...
If it is not connected to a water line then you cannot use the hot water faucet or the start/brew button, you will have to manually brew coffee by pouring the water into the reservoir.
Nov 16, 2011 | Brewmatic LA3 Coffee Maker
How to decalcify a Saeco Royal coffee bar?
To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to "direct water connection" and push the enter. Chose "off" and push enter. Push "escape". Use the arrows on the left to scroll down until you come to "Descale". Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again
Sep 08, 2010 | Saeco Royal Professional Espresso Machine
Water leaking out the bottom
CHECK THE SEAL WATER TANK ON TOP
Aug 19, 2009 | Keurig B60 Coffee Maker
Gaggia baby 18 momths old water coming through steam bit but no water coming through coffe bit any suggestions libby
HI
If you have a pre-grind button on your machine, push it but don't put any coffee in the brew unit. Push any of the coffee buttons, and see if water will come out then. If it does not, then you have a plugged brew unit and the brew head needs cleaning. I have directions for cleaning.
Jul 13, 2009 | Gaggia Syncrony Compact Coffee...
Astoria SAE 1 trickle of water from hot water faucet
Some models have an economiser valve, which mixes hot water from boiler with cold from inlet line, that could be closed or obstructed. The line from the boiler to the solenoid or the pipe inside the boiler could be blocked.
Mar 20, 2009 | Astoria Argenta SAE-2 Espresso Machine
Filled with water overnight
Hi When I plug it in is there any light on the panel that will come on without hooking it up the water lines???
Jul 11, 2008 | Kenmore Elite 45986 Front Load Washer
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
