Question about Sport & Outdoor - Others
Need a off/on switch for homelite generator model #lr4400 serl.#h50640743
3 Suggested Answers
  • 3 Answers
SOURCE: I am looking for an owner manual for a LR4400
Check with briggs
Posted on Jul 19, 2010
SOURCE: I'm changing the oil in
i use hd 10w30 in mine and it works fine.
Posted on Sep 10, 2011
Homelite LR5550 serges when it runs is there a way to set the governor so will run smooth
Try opening the high speed jet about 1/8 turn. If that don't work clean the carb.
Jul 07, 2014 | Garden
Homelite generator
would need to know engine size, and model as there is 2 strock and 4 stroke models.
Jan 08, 2014 | Electrical Supplies
Generator does not generate power.
Check, capacitor rotor brushes and slip rings for cleanliness. Check for DC voltage on rotor brushes during craking. If still nothing try flashing the rotor, after that check rotor windings and stator.
Oct 04, 2013 | Homelite Lr4400 Generators
Homelight generator LR4400, Our generator starts up but we can not keep it running, it dies within a minute. We checked the filters, drained old oil and fuel out. Not sure what the next step is?
My first thought is the fuel tank vent it plugged. Try running it with the fuel cap loose and see what happens. If it now runs fine this prooves the vent is plugged. Some fuel caps have a small hole in it to vent the tank. Look at the cap to find the vent hole and clean it out.
Aug 04, 2013 | Homelite Garden
I have a homelite 720 generator but cant fingd the instruction manual and i need to know if the charger leads only charge a battery or can be used as jump leads i know this might sound stupid but i wo
I can't find any reference to a Homelite model 720 generator but most battery charging systems do not supply enough amps to run a car starter. Battery chargers usually work in the two (trickle) to ten amp range. Car starters need way more amps to have enough power to turn an engine over, depending on the size and number of cylinders in the motor. Some chargers have a switch with a 60 amp 'start' position to help the battery turn the motor over, but without that there is little chance the charger side of your generator will supply enough amps to help your battery.
Feb 21, 2012 | Cars & Trucks
I need a wiring diagram for a homelite HRI4400HD generator please.
Go to Homelite's web page http://www.homelite.com/ and you enter your Model Number and download the Owner's Manual, that should have wiring diagram in it. If you don't find it. contact Homelite Customer Service.
Hope this helps you find what you need.
Apr 18, 2011 | Heating & Cooling
Gas leaking on plate between air filter and carb on my Homelite LR4400
your carberator float may be stuck causing the bowl to overflow.
Aug 28, 2010 | Electrical Supplies
Homelite generator model # LR 5500 not producing electricity
I have the same unit and same problem.
I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
Mar 07, 2010 | Electrical Supplies
Sport & Outdoor - Others Logo
206 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
