Question about KitchenAid K45SS Classic Stand Mixer
Leaking oil above beater - KitchenAid K45SS Classic Stand Mixer
  • 185 Answers
The gearcase grease and housing gasket needs replacement. this will require alot of disassembly and the use of kitchen aid specific grease.
Posted on Aug 25, 2010
The beater will not come off and it's leaking oil
These are two separate problems.
The beater is probably being held on by dried/solidified flour. Try keeping the section where the beater joins the mixer head wet with water to loosen up the dried "glue." (Give it some time.)
The oil leak is caused by the grease separating. You can try running the mixer on high for a few minutes to re-mix the grease. If this does not correct things, you will need to clean out the old grease from the gearcase and replace it with new. See the Service Manual at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Jun 01, 2014 | KitchenAid 32685 Mixer
Mixmaster is leaking oil from the beaters
Here is a link on YouTube. It may not be for your model but it can give you an idea: http://www.youtube.com/watch?v=8eKHVvNX5eY
How to Fix KitchenAid Stand Mixer That Is Leaking Oil
Apr 04, 2014 | Food Mixers
Beater hard to remove...oil leaking out of the place where you insert the beater
The agitater shaft that the beater attaches to is bent and needs to be replaced. It's easy to do . You should replace the shaft , pin, and seal above it. You may also want to replace the part the shaft mount through, to stop oil leak. You can google the model number and find a parts breakdown for the part numbers .
Aug 26, 2011 | KitchenAid 32685 Mixer
My K45SS is leaking some kind of oil or grease from the part of the mixer above where the mixer part attaches. It otherwise seems to be functioning fine.
its gear oil from the gear box that the motor turns to make the beaters turn,you need to replace the seals or keep adding food grade oil before you dry out the gearbox and ruin it
Mar 09, 2010 | KitchenAid K45SS Classic Stand Mixer
We have oil leaking from around the rotating part that holds the beaters. How do I stop it?
the beater is simply pushed away from the bowl edge temporarily and stops, as the rubber groove loses contact with the rotating bowl.
Jan 31, 2010 | KitchenAid Food Mixers
I have oil leaking from the beater shaft. a lot
TRY REPLACING GREASE IN GEARBOX AND MAKE SURE YOUR FELT COVER IS IN PLACE (AND CLEAN) THAT SITS UNDER GEARBOX.
**** KENWOODCHEFUSEDMIXERSANDSPARES
Jan 05, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaide mixer...leaking oil underside of
KitchenAid uses a grease in the transmission, and anything that may drip from the transmission will be very low in quantity.
If you want to disassemble, clean, and re-grease to remove the liquid part that has weeped out of the existing grease, do so with a food safe grease.
Dec 21, 2009 | KitchenAid Food Mixers
Leaking oil
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Jun 27, 2009 | KitchenAid Classic Stand Mixer
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
Leaking oil
thats the planetary seal thats leaking.the seal is cheap its the labor that may be costly.is it just a nuisance leak or a lot?you dont want any oil to get in your mix.
Aug 16, 2007 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid K45SS Classic Stand Mixer Logo
90 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
