Question about Acer 22" X223w LCD Monitor
I have an acer x223w and it's like there is no power going to it. I tried different power cords and a different outlet and it still doesn't work. It's only 8 months old.
  • 11,361 Answers
I would get it repair under warranty ASAP, the power supply may have gone out.<br /> It will void the warranty if you open it up.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt"><a rel='nofollow' href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a rel='nofollow' href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span>
Posted on Aug 25, 2010
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
When I try to power up my acer aspire M1201 the power button isn't responding
Check to make sure that power is reaching the power supply of your unit. If it is and still does not work, then the issue is with the supply that needs replacement. Common malady.
Jun 20, 2017 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
Hp PSC1210 All-In-One not turning on
HP makes a couple of different power cords for the PSC 1210 and their other printers. First make sure you are using the correct power cord (Amperage and voltage). Unplug the power cord (from the wall and the printer and from a power module if you have one). Leave all of the sections unplugged for at least 15 seconds to reset the power module/printer.
Next connect the power cord to the wall outlet and to the power module if present and check if the LED (if present lights up). If it doesn't try another outlet. In either case, check what the outlet voltage/amperage is at the end of the power cord with a multimeter (before you plug it into the printer). If you have a power module, then check the Amperage (it will be a DC current out).
If you are not getting the correct voltage and amperage out or the LED doesn't light (with a known good outlet), try a different power cord/module.
You can order these from HP.
If you have the correct power at the cord, plug the power cord into the printer and attempt to turn it on. (Press and release the power button.) If the printer still doesn't come on, the unit needs service. Contact HP if the printer is under warranty. Decide if it is worth fixing if it is out of warranty.
I hope this helps.
(I've had to use the HP Repair/Replacement service after a unit was in a home that was hit by lightning. Due to printer availability, an HP gift card was provided to buy a new printer.)
Dec 11, 2011 | HP PSC 1210 All-In-One InkJet Printer
I cannot get the sound to work. There is a cord for the monitor that I THINK is for the sound but there is no reciprocal port on the hard drive.
Acer X223W does not have built-in speakers. There are three ports on the back: 1 AC input port, 2 video input ports (DVI and VGA).
Mar 28, 2010 | Acer 22" X223w LCD Monitor
Power cord isn't working for Acer 5720
I have had good success with this notebook universal power supply. Just make sure that the clip you need is included with the item. Or you could buy an OEM (original equipment manufacture) model.
Hope this helps.
http://www.cablesunlimited.com/products/Prod_Individual3.aspx?groupcode=I3550
Nov 05, 2009 | Acer (56.04145.901) (5604145901) Power...
Monitor stops showing desktop
probably needs new voltage regulator for backlight. it would probably be cheaper to just buy a new monitor
Aug 14, 2009 | Acer 22" X223w LCD Monitor
I am trying to install my new X223W monitor to my IBM thinkpad laptop. I can't do it even though I have the 15 Point connections and the power cord installed correctly. No pic on the monitor.
Go to your helps directory in the Thinkpad and there should be a helps to assist you with you monitor to laptop connection.
Also look at the monitor instruction to see if you have missed a step or two.
There is also an IBM forum online for IBM Thinkpad owners to get specific help.
Aug 05, 2009 | Acer 22" X223w LCD Monitor
Acer X223W flickers using DVI cable, but ok with VGA!!??
Acer X223W flickers using DVI cable, but ok with VGA!!?? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
715G2892 2 3 Acer PWTVAC21MQDL Power Supply for X223W
Dec 19, 2008 | Acer 22" X223w LCD Monitor
Wireless problem
Are u staying at the same place when u plug and unplug the AC power outlet?
Jun 03, 2007 | Acer Aspire 5003WLMi Notebook
Acer 22" X223w LCD Monitor Logo
147 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
