Question about Graco 9445DOH Crib
How do I put away/fold avalon play yard (moving series) as Ihave lost the instructions. Thank you
5 Suggested Answers
SOURCE: Folding up Cosco play yard
To fold the Play Yard:
1) Take out floorboard. Pull up on finger tab in center of floor
and raise midway to top rail.
2) To unlock top rails, push in on indicator buttons on each side
of rail. (Pull up slightly then push down.) Do this for each of
the top rails in any order.
(Note: If locks fail to release, pull center finger tab and lift
center lock higher.)
3) Continue to pull up on finger tab to raise the floor and pull in
the legs.
4) Wrap floorboard around play yard and fasten strips. Place
inside carry bag for easy transportation.
Posted on Feb 25, 2008
Chummy_57C
  • 6 Answers
My wife and I have the same model for visits by our granddaughter. She was having the same trouble as were you and, like you, we did not have instructions.
I'm happy to share with you what I found to close the model up for storage. It may not be the same as what the manufacturer envisioned but it worked for us.
-- With the pad removed from the inside of the Pack n Play, pull up on the red handle so as to loosen the legs;
-- Next, you will find there is a big button in the middle of each of the long sides of the Pack n Play. Start with either long side. You will have to press very hard on either side of that button; I found it helpful to use both hands, one pressing on the outside of the playpen, the other hand pressing on the inside of the playpen. Pressing these together will loosen the long support arm at the open top of the Pack n Play.
-- Do the same for the opposite long side.
-- You will also do the same, one button, one side at a time, for each of the two short sides of the Pack n Play.
-- Now pull up on the red handle in the middle, and guide the four corners so they meet and close.
-- Cover.
I found the buttons may not have fully allowed the support arms to collapse, thus blocking the Pack n Play from folding down completely. If so, try pressing the button again (both the outside and the inside at the same time).
Hope this helps!
Posted on May 22, 2009
  • 130 Answers
SOURCE: I lost the instructions to my graco pack n play
ON THE BOTTOM IN MIDDLE OF CRIB ,PUSH UP
Posted on Jul 15, 2009
Ironfist109
  • 3018 Answers
SOURCE: how do you lock an
  • These playpens have a safety feature.
  1. First thing is to make sure the center of the playpen is up in the air.
  2. First lock the short side rails. They will click into place.
  3. Now lift up and lock the long set of rails.
  4. Now you want to push the center piece (floor) down all the way.
  5. Now your playpen is set up.
  6. When you go to put it up you will pull the floor up first and then release the side rails.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jun 17, 2011
CAN'T CLOSE CARTER PLAY YARD
1. Take out mattress
2. Pull up from the center of the bottom (from inside)
3. Press buttons beneath fabric on playpen sides to disengage locks
4. Fold sides in to form rectangle shape
5. Place change parts on top
6. Fold mattress around everything, and secure with velco
7. Place in bag.
Instructions at this link: https://docs.google.com/viewer?a=v&q=cache:6nDv33smp4cJ:www.summerinfant.com/getattachment/9f4739f2-13ea-4342-833f-98fcdcd697a0/Carter-s%25C2%25AE-Bumble-Comfort-n--Care-Playard---Changer.aspx+&hl=en&gl=us&pid=bl&srcid=ADGEEShem_Qqk1mAetDfL0flJy-kUHyeo5y_9U2-H9ORsLfrJVBmfkuSbdi4U0aEZspq70zeZD8RJd-k2ABFHWwubl4RC0krcPK2V5vsOuu_KCWFnCwVYsN_LJXCoKNDS-9msppsRLda&sig=AHIEtbQbqIlqXbjMY84PvQ26usJHXF14wg
Hope that helps!
Jan 04, 2013 | Summer Infant Carters Bumble Comfort n...
How do I to fold a safety first pack n play?
This is not a product available in the UK so we are unable to assist. Please contact your retailer for assistance.
Dec 15, 2011 | Safety 1st Disney Care Center Play Yard...
Can you send me the directions for setting up the cosco playpen
Try this step by step instructions Hope it help you
Instructions
1. Unfasten the floorboard from the folded play yard frame by loosening the hook and loop tabs holding it in place.
2. Unfold the play yard and set it upright with its four legs on the floor. Pull out on opposite corners to spread the legs of the frame.
3. Pull up on the plastic handle in the center of the floor of the play yard to unlock it fully.
4. Pull up firmly on the center of each of the four side rails until they click into place, while continuing to pull up on the center handle.
5. Push the center lock down until it clicks all of the legs into place.
6. Place the padded floorboard into the play yard.
7. Locate the two hook and loop tabs located on the underside of the floorboard and pull them through the slots in the bottom of the play yard frame. Secure the tabs underneath the play yard.
Jul 02, 2011 | Cosco Juvenile Cosco Funsport Playard
The avalon play yard will not fold- one of the short arms will only half collapse no matter what I try.
Have you tried pulling the centre up almost all the way and then releasing the side?
Oct 29, 2010 | Toys
I purchased an Avalon play yard and it did not come with instructions. I cannot get the sides of the playpen to stay in the locked position. What am I doing wrong?
I have the same play yard and it is a funny one to figure out but I believe that you lock the sides first then push the bottom down to lock it in place hope this helps
Sep 03, 2010 | Toys
Need instructions on folding and storing an 8 yr old pack n play?I have cleaned it and am having trouble knowing how to fold it up so it will fit in the cover for storage?
I have one that is about this old, so if it is the same one, the instructions for how to fold it should be printed on the very bottom of the play yard. If they are not, then try to pull the center part up halfway. Next, push up on each side where the arrows are and as you do this, it should start to collapse and you should be able to fold it completely by pulling the center all the way up.
Hope that helps!
Aug 29, 2009 | Graco Baby Gear
Setup/takedown instructions
ihave a Avalon on the move series playpen model AP11 and i can not get it to close for traveling
Jul 13, 2009 | Avalon Baby Gear
-- Cover.
Hope this helps!
Jan 06, 2009 | Cosco Beatrix Potter Playard Crib
you also need to hold one of the middle indicator tabs on the longer side..because if you don't do that it will not shut... and make sure the 2 legs go inside with the center of the play pen
Dec 03, 2007 | Cosco Beatrix Potter Playard Crib
Graco 9445DOH Crib Logo
720 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
