Question about Sears 61301 Gas Kitchen Range
I have a galaxy gas range says it is set up for gas or propane how do i switch it and is it expensive
  • 5,102 Answers
The cost of the parts is low. Many ranges have the conversion kit attached to the back of the unit. (If installed, pull the range away from the wall and then check the back. Another likely spot is behind the storage drawer.) If the parts aren't provided, then check your manual for information on ordering the conversion kit. (At least one range I've researched had a price under $20 for the conversion kit.)
The biggest cost is to get a licensed installer to do the conversion. This is required to maintain the warranty. It is also required by law in some states. Talk to your gas company (most appliance shops do not have staff that handle propane conversions).
The instructions are included with the conversion kit. It's fairly simple and takes a screwdriver, wrench and ratchet with correct sized socket (mine took a 10mm). A nutdriver can be helpful. Check your instructions for any other tools you need. With the stove unplugged and disconnected from the gas supply, turn over the LP/NG part in the regulator (do not remove the entire regulator). Adjust the air flow damper. Remove the current orifices for both the range and the stovetop. For best results do these one at a time (the orifices are labeled and are for specific locations). In the oven, you need to remove a few covers to reach the various dampers and orifices.
Then connect the stove back to the incoming gas line and power supply (use a new flexible gas line for the connection to the regulator). Check for leaks. Then you may need to adjust the flame for each of the inlets. The stovetop burners usually have a set screw behind the knob so turn on the flame and then remove the knob. The set screw takes a very small screwdriver.
I hope this helps.
(please note I did this from memory after reading the directions on the new stove we had delivered about 2 months ago. That was an LG stove so some differences in the instructions are inevitable.)
Posted on Aug 25, 2010
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
How can you tell if a 1985 wolf range burnes gas or propane? it says propane, but we bought it saying it was for gas? And how much would it cost to change out? Thanks, Mary Kaye
Most ranges are easy to convert from propane to gas or vice versa. If there is a gas regulator installed on the back gas inlet, you could see if it is running 3-6" WC or 10-12" WC, The latter is for propane. If no regulator is present the orifice sizes will need to be checked. Propane has a higher caloric value than natural gas so the orifices are smaller. One way to see would be to install the oven. If the orifices are for propane and you are using natural gas there will be too little flame. I would estimate a conversion would cost no more than $250.00 to $300.00 depending on where you are. I would hire a professional to verify. I know it is expensive but the technician will be able to check your older oven (1985) for potentially dangerous gas leaks etc while he is there.
Jun 06, 2011 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
How to convert a 61" residential rangefrom butane to natural gas?
Ranges come set from the factory for natural gas. To convert it to propane, you should call your propane co and have a qualified serviceman do the work. You can void the warranty if you try to do it yourself and break something or don't convert it correctly. On an expensive range like this, you'll be better off having a professional do it right and keep that warranty intact. It could take 1 1/2 to 2 hours to complete the job. You may need to purchase an LP conversion kit if some of the orifices have to be exchanged, like on a unit with sealed stovetop burners. Write down the make, model # and serial # for reference when you make an appt to have it done. Hope that helps.
May 22, 2010 | Imperial Commercial Cooking Equipment...
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
How do u switch it from natural gas to propane
You can purchase a set of propane gas orifices to swap out for the natural gas orifices that your unit has presently.
Contact a local appliance parts supplier and ask for the propane gas orifices for your specific model.
If you swap them out, you will be good to go.
May 13, 2010 | Magic Chef 31000 Gas Kitchen Range
Maytag Range Model MGR5870 how to convert to propane
set the regulator to propane and change the orfices to the blk ones. copper is for nat gas / black for propane .. thanks hope this helped .mm
Dec 22, 2009 | Maytag MGS5870 Gas Kitchen Range
Iwant to change from natural gas to propane,wehat
If you live WAY out in the sticks, all you need is a tank of propane and the reqired fittings,BUT,if you live in the good old suburbs or the city you'd better have the gas company do the job. After all they have to shut off the gas feed to your house anyway. Good luck,Dana
Aug 21, 2009 | Vulcan 36L Gas Kitchen Range
Switching from gas to propane, I have the parts,
call your propane provider as they often have a technician who comes out just to keep you on as a good customer.
if that isnt the case you just have to change the orifices over from natural gas to propane and adjust the flame levels
Aug 20, 2009 | Kitchen Ranges
Kenmore 78618 gas range
Yes, the orifice will is in the center of each burner and will unscrew.  Make sure new orifices get installed in the correct burner or it won't work properly.  I think you will use a 6mm nut driver to unscrew the orifices.  Can use a ratchet and socket also.
Oct 11, 2007 | Sears 61301 Gas Kitchen Range
Nat gas to propane conversion
With the gas turned OFF, you will need to find the gas regulator on the range. It will located in the back of the oven along the bottom somewhere. It's usually a square shaped valve with a nut on top of it. The gas valve orifice is located under the nut. All you need to do is remove the nut, take the orifice out, flip the orifice over and re-install to convert from one type of gas to the other. It should be marked which side is LP (propane) and which side is for Natural Gas. LP will have a smaller orifice opening than Natural. You will want to make sure the orifice size you are using is facing UP, then screw the nut back on the regulator. You will also have to do this for all the surface burners (if you haven't done so already). You will know if you have the orifice turned the wrong way because the flames will be too high, the oven will get way too hot and there will be soot everywhere. Hope this helps you.
Aug 11, 2007 | Sears 61301 Gas Kitchen Range
Sears 61301 Gas Kitchen Range Logo
179 people viewed this question
Top Sears Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Sears Kitchen Range Expert? Answer questions, earn points and help others
