Question about Kenmore 53642 / 53644 Side by Side Refrigerator
THE MOTOR IS WORKING BUT THE AIR COOL IS NOT FLUID TO THE REFRIGERATOR SIDE THE FREEZER IS WORKING GOOD ONLY THE REFRIGERATOR SIDE IS NOT
  • Mike Smith
    Mike Smith Aug 25, 2010
    need complete model number to help
  • 3 Answers
If we don't clean our refrigerator coils with a coil cleaning brush and shop vac every year then eventually the refrigerator may stop cooling. Go to a appliance parts store and get the brush and ask them how to use it, and brush out all of the debri built up. Do unplug the unit first or the fan may cut you. Brush off the compressor also. Vaccuum it all up and plug it in and it may begin to cycle properly within a few hours. The appliance repair industry gets rich of people like us simply because we lack this knowledge. Or in my case I was to lazy to do it until my refer stopped working. Just did it today and now it is working like a champ. I get to keep my money and buy diapers or go get a relaxation massage to reduce the stress of my oil filter going on on my Malibu the same day. lol Good Luck and God Bless.
Former Appliance SalesPerson.
Posted on Aug 25, 2010
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
The freezer part is working good but the cooler side cools but not enough
the damper vent door between the freezer and fridge section isnt opening up to let cold air in from the freezer side to cool the fridge side,its behind a plastic grille near the top between the 2 compartments,there is also an evaporator fan near this and it also needs to be operating to move the cool air
May 24, 2011 | Jenn-Air JSD2789GES Side by Side...
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Will freezer side work if frig side is out
The freezer will appear to still work for awhile after the fresh food side fail to maintain a cool temp, you will need to remove the back in the freezer section and see if the fan motor is turning, if the fan motor is not turning you willl need to replace the fan motor and this will correct the problem and allow cool air to circulate to the fresh food section and cool the fresh food side of the refrigerator
Apr 17, 2010 | Refrigerators
Freezer stopped making ice and now coils in bottom of freezer r freezing up..this is a side by side refrigerator
shut off motors .....let it completely defrost,,,restart the fridge and STOP PACKING IT SO FULL allowing air to flow . if air can't flow freely, the ice maker stops and the freezer frosts up ,...causing the refrigerator side to not cool as well as it should.
the freezer side only works within certain parameters.
HTH !
Mar 29, 2010 | Frigidaire FRS26R4A Side by Side...
Refrigerator not cooling.
Hi and welcome to FixYa,
Almost always, your described problem could be either:
  • evaporator fan/blower is faulty; or
  • air passgaeway blocked or vent is blocked or closed.
The refrigerator section gets its cold air from the freezer. If the freezer is working then the frozen air would have to be drawn to the refrigerator side by the fan. If the fan is not working or the air passage way is blocked, then no frozen air would be moving towards the refrigerator side. result would be as you described.
In some instances, it could be the thermostat of the refrigerator but this would be least likely.
Good luck and thank you for using FixYa.
Feb 22, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Water stopped and freezer not cooling
you probably have a bad evap fan motor in the freezer compartment. when this motor goes bad it doesnt distribute the cold air around causin subfreezing temp in the bottom of the freezer it then migrates into the fresh food compartment. you can order the motor by the mod# of your refrig and it is fairly easy to change yourself. good luck peyton
Jan 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Fridge not cooling
Check and see if your evaporator fan motor is working in the freezer. Also, if your defrost system is not working and your evaporator coil is frosted up, you will not get any cold air to the refrigerator section. You should see alot of frost on the back wall of the freezer where the evaporator coil is located. If your evaporator fan motor is working and there is no frost build up on the coil, the air diffuser to the refrigerator section may be the problem. Put your hand in front of it when the evaporator fan motor is running and feel if any air is coming thru. There are a number of conditions that can cause your problem. This should get you started! Visit me on Ebay as username: themackshack. Good luck! Mack
Mar 23, 2008 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
24 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
