Question about Craftsman Garden
Replaceing fuel lines on a mod # 358.352161 16" 2.2 cubic inch chain saw. The lines have all rotted.
4 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Posted on Oct 24, 2009
hunter19_46m
  • 7482 Answers
SOURCE: need to know about fuel
Hi arisaleman...
This drawing is how most chainsaws,weedeaters,and most 2 cycle small engines fuel systems are run.
Please take time to rate me
Posted on Sep 10, 2011
hunter19_46m
  • 7482 Answers
SOURCE: replaceing fuel line in polan
Hi owjbhend...
Use a piece of wire and insert it into the fuel line, then bend a hook in the end and hook it over the end of the fuel line...lubricate the fuel line with some vaseoline very lightly...about the first one inch of the fuel line and then use your fingers to start the fuel line into the tank, once you have the fuel line in the tank give enough to hook the fuel filter to and so it can be dropped back into the tank.
Below is a drawing of how to route the fuel lines.
Please take time to rate me thumbs up
Posted on Sep 16, 2011
Why won't the saw run other than when the choke is in the 1/2 position and dies whenever throttle is applied?
Your carb is starving gas from your saw. You will have to remove the carb. and take it apart, check the diaphragms for hardening or splitting, clean all passages and screen. There is a lot of small parts that have to be put back together correctly, also the diaphragms and their gaskets have to be installed right.
Feb 27, 2015 | Poulan Pro Pp5020av 20-inch 50cc 2 Stroke...
My craftsman chain saw 18 will not start
The 3 things needed for an engine to run:
1. Compression (Cylinder, Piston, rings, gaskets)
2. Ignition (Spark plug, ignition module/coil)
3. Fuel (Fuel lines, Carburetor, gaskets, bad fuel)
More than Likely I would start by checking fuel related since that is usually the biggest offender (fuel lines broken/dry rotted, bad carb.)
Jun 19, 2014 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Replaceing fuel line in polan 3300 chain saw
Hi owjbhend...
Sep 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have an older model Mac 4600 18" chain
Go to Mcculloch.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 27, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel lines rotted off of my McCulloch 4600 chain saw
Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. Hope this helps!
May 18, 2010 | McCulloch Garden
2.0 Cubic Inch Montgomery Ward gas chain saw, 10 inch cutting bar
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Oct 26, 2009 | Garden
Fuel lines have rotted off. need to replace then
Mr Tittle;
Poulan.com
HTH
Lou
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Fuel lines
The main fuel line goes to the bottom of the tank. The other, sometimes larger line goes to the primer bulb. This line goes just inside the tank, not more than 1"(inch).
May 20, 2009 | Poulan Pro Chain Saw 46cc 20"
I need a repair manual for a McCullough gas, 35 chain saw
Mc chain saw fuel lines rotted away need to know where they go
How the primer lines go! There are 2 outlets on carb. two tank lines two primer lines
Jan 11, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
150 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
