Question about Yamaha RX-V1200 Receiver
Yamaha rx-v1200 volume control
Thanks for the help. i've never really done repairs, so i'll need a little guidance. is there any site where i can find some sort of schematics or guide for opening up the receiver and locating these parts? or, any tips for where i might purchase replacement parts (volume control switch)?
    Novelist:
    Champion:
  • 236 Answers
If you are not really that technical type that can make repairs then it will be very hard for you to replace it yourself. not hard to find the volume control, it is mounted on a board. you dismantle the board first then remove desolder the volume control. it think you can onyl get the parts from yamaha service.
Posted on May 08, 2008
  • Redentor Rivera May 11, 2008
    for you to have even how to open the cases, you need to have a service manual but i dont think yamaha can provide you with that. Maybe you can get the schematics but not the assembly. but if you are only replacing the volume, you dont really need schematics. your volume control has gopt terminals that you can not interchange. but you can only get the exact replacement with yamaha service in your area.
Yamaha RA-V1200 wont turn on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .if it stays on whit no wires attached than u have short connection at speaker wires . if doesn`t come on then try to fasten screws at back of the unit , may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happened to me on RX-V592
Jan 16, 2013 | Yamaha RX-V1200 Receiver
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
I have a Yamaha RX-V1200 receiver (6.1).
I would get it assessed to see if the unit is worth repairing. There are Ic's and stand alone transistors that could add up when it comes to repairs.
Mar 28, 2012 | Yamaha RX-V1200 Receiver
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
Yamaha RX-V800 volume knob on receiver not working.
It sounds like the volume control pod has gone bad and needs replaced (The knob shaft connects to the pod main body and the inside of the volume pod is what controls the rate of volume,If the inside becomes worn ,broken or dirty the volume will become erratic) Replace volume pod ! ..You may try cleaning by taking off the volume knob and getting a can of pressure air and blowing the dust out!
Please rate response!!
Jan 06, 2009 | Yamaha RX-V800 Receiver
Yamaha RX-V390
Try reseting the Yamaha-Shut the power off, and while holding down presets 1,2 and 3 press power on.
Nov 24, 2008 | Motorola Mobility DRC800 Universal Remote...
AV receiver RX-v1200
What happens when you turn it back on?? Are there any messages on the display??
Jul 03, 2008 | Yamaha RX-V1200 Receiver
Volume knob quirks
if you know how to repair, then replace the volume control switch. it is a digital type/mechanical type of switch with silicone oil on it to prevent sudden turn of volume. if i were the repairman i can simply clean the contacts of the volume control and pour silicon oil again. but i really dont know in your area if they try to clean those.
May 03, 2008 | Yamaha RX-V1200 Receiver
Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Nov 02, 2007 | Yamaha RX-V1200 Receiver
Yamaha RX-V1200 Receiver Logo
340 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
