I took the back cover off and saw three round lenses i think where is the light bulb located
  • 11,361 Answers
You have CRT rear projection TV, those are the RED, BLUE, and GREEN CRT.
Make
Posted on Aug 25, 2010
How do I remove the cover to replace the light bulbs on a Round Nautilus brand bathroom exhaust fan from the 1980's.
Most exhaust fan covers use a spring steel wire in a V shaped configuration. The bottom of the V is attached to the cover. There is a slot in the fan housing and by pinching the tops of the V togetherand insert them in the slots the spring pressure pulls the cover up tight to the ceiling.Carefully pulling the cover down enough to reach over the cover and pinch thewires together should allow the cover to be removed. Hope this helps.
. Bob
Aug 09, 2014 | Broan nutone Broan/nautilus Bathroom...
Projection bulb location ?
Remove the large black back cover and the projection or color bulbs as they are called, will be looking right at you. Three big lenses will be there. That is what you are looking for.
Apr 16, 2014 | Sony KP-57WS510 57" Rear Projection HDTV
Replacing rear number plate bulb peugeot 306 hdi estate car
Pop off the clear plastic lenses. Replace bulbs, pop back on lenses. They are T10 or 501 or w5w, all mean the same thing.
I replaced mine with LED bulbs, same as front sidelights, brake lights in tailgate window and interior. If you use LED's you must put them in the right way round, if not working unplug and turn 180 degrees.
Apr 06, 2012 | Cars & Trucks
How do you change the low beam headlight, the manual says call a dealer. Come on, for a headlight. Can anyone tell me how to remove everything to do it myself, i have the bulb. candace
Driverside- Reach behinde the headlight remove the rubber cover twist the bulb out and replace. Not hard just have to be patient and you will see how easy it is. Took me 5 min.
Pass Side- Ok you would think how to I reach back there? Ok ready>> Take out the three screws that hold on the airbox cover. Take off the airbox cover the whold back of the light is now exposed. Take off the rubber and replace the light or lights. Super simple.
Aug 05, 2010 | 2005 Chevrolet TrailBlazer
Need to replace grille lamps
When you look at the glass lamp covers (lenses), you will see a little raised section either at the front or back of the lense, depending how the lense was replaced previously. You need to put the largest screwdriver blade you can under the lip and turn it slightly. The cover should move and then ease the screwdriver round the lense until the lense comes clear.
Note. Cooking gunge may may this action difficult as it will cause the lense to stick and also when you replace the lense, you will see on the inside of it there is a moulding cut away to clear the bulb. Make sure when the lense is replaced, the recess is positioned so that it clears the bulb. Whilst you have the lenses out, use the Lakeland brush on oven cleaner to give them a good clean. The end result makes a difference!
Sep 30, 2009 | Stoves 720EF Electric Double Oven
Replacing license plate lights on Chevy Trailblazer
I just had the same problem. I took the cover off, saw the white bulb base, twisted it to take it out, but it popped back inside the door. I got it out, but it wouldn't pull through, so I twisted it back in place and went to Autozone to get new bulb. Once I saw the new bulb, it was obvious, just the bulb itself pulls out. There's so little room to work, I couldn't get it with just my fingers - - maybe rubber gloves would have worked, but I used pliers, lightly, wiggled it a little and it popped right out. I had a similar issue once with the taillight bulb and had to break the bulb and then grip the remaining filament wires with pliers to get it out, so that was my backup plan, just in case.
Hope this helps others.
Apr 14, 2009 | 2002 Chevrolet TrailBlazer
Steps to replacing right front signal light bulb in 2005 Malibu
Raise hood and remove two hex bolts holding light assembly. You will see three round rubber covers, approximately 4" in diameter. Unscrew the one to the far left, giving access to the signal light bulb. The bulb pulls straight out. Insert new bulb, replace rubber cover, attacht light assembly back to vehicle with hex bolts, close hood, and pat yourself on the back for job well done.
Mar 30, 2009 | 2005 Chevrolet Malibu
2002 trailblazer
All you have to do is find the "round rubber cover" on the back of the headlamp, pry it out with a flathead screwdriver and the lamp is right there.
To remove the headlamp assembly on a Trailblazer, remove the plastic panel that covers the hood latch assembly.
Take the cover for the air filter in order to get to the low beam cover.
Take the 3 screws out of the air filter cover and remove. You will then be able to get to the back of the low beam lamp. The high beam is reachable without this hassle.
Oct 07, 2008 | 2002 Chevrolet TrailBlazer
Replace tail light bulb
The process for changing the tail light bulbs for a 2002 New Beetle in my case a TDI is relatively simple. To remove the lense and gain access to the bulbs you first need to release the lense holder from inside the trunk by completely unscrewing the large plastic wing nut that is under a round plastic panel that's located almost directly behind the rear brake light lense. To gain access to the plastic wing nut remove the round panel by gently prying it off. After this is done you release the lense by using something flat like a dinner table knife to pry and release the clip that holds the lense in place. Locating the clip: The rear fender has two seams that end at the light lense, the inboard seam (the one closest to the hatch)is where you want to insert the table knife to pry the metal clip that holds the lens in place. Gently and carefully insert the knife blade directly at the seam and pry upward to release the lense. Once the clip releases pull the lens the rest of the way and remove the bulbs by turning the bulb holder sockets couter-clockwise. After this is done remove bulbs by slightly pushing down on the bulb and turning it counter-clockwise. The reinstall is reverse of the removal the procedure.When re-installing take care to clock the lense where the metal clip and the lense protrusions end up in the same position as before. Note: you may need to assist sliding the lens retaining clip in with the knife when reinstalling! Good luck
May 15, 2008 | 2003 Volkswagen New Beetle Convertible
Bulb Shattered...After replacement does nothing!!!!!
Did you get any anwsers as I'm having the exact same problem with my projector, the noise for few seconds, the light flashing...
Thanks
Dec 19, 2007 | InFocus ScreenPlay 4805 Multimedia...
Televison & Video Logo
Top Televison & Video Experts
