Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
I have a built-in 48" KitchenAid fridge KSSC48FTS00. It is cooling fine. However, the beautiful blue display panel and the temp # are all out. The interior lights are now out too. I have turned it off using the on/off button under the exterior grill and have also shut power down completely in our homes circuit breaker. Turned everything back on, but the fridge is still dark. Could a power surge cause this? Or is it something else?
tborn6
  • 700 Answers
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Posted on Apr 04, 2009
tborn6
  • 700 Answers
SOURCE: How long should I wait to turn back on?
around 24 hours should be ok
Posted on Apr 20, 2009
relaga58
  • 158 Answers
SOURCE: FRIDGE FREEZES EVERYTHING...DIGITAL PANEL DOES NOT CHANGE THE TEMP.
try off and on power
Posted on May 05, 2009
  • 16 Answers
SOURCE: Kitchenaid Fridge -- burnt rubber smell
sound like defrost timer going out slowly
Posted on Jun 02, 2009
aasc
  • 1606 Answers
SOURCE: refrigerator not cooling / fan not turning
Yes , replace the fan motor . Part number 833697 . Also make sure the coils are clean of dust , lint etc. Be sure to reinstall the back panel , after replaceing the motor , as this motor cools the coils and the compressor . ( only 3 screws hold the fan motor on , easily repaired .)
Posted on Sep 16, 2009
Testimonial: "Thank you for the part number! Didn't expect that. I should have it up and running as soon as I pick up the part. Thanks again."
Kitchenaid side by side refrigerator/power is on/control panel display is lit up/Cooling is on/how do I reset the Temperature Display to get freezer at 0 degrees and fridge at 37 degrees
the temp you see are the temp valve inside, the set temp is only displayed while you are setting it. It maybe in defrost and you would see higher that set temp valves, if after an hour you do not see the temp come back down to normal operating values you should then see additional assistance.
Dec 29, 2017 | KitchenAid Refrigerators
Over temp light on and refrigerator/freezer not staying cold.
Extended warranties usually are not worth the cost. My guess is that KitchenAid wants you to pay $73 out of pocket even though it should be absorbed as part of the warranty replacement of the refrigeration system.
Mar 08, 2017 | KitchenAid KBRC36FMS Bottom Freezer...
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
My freezer is freezing food fine but my refrigerator seems to be warm and not cooling like it should. The temp control has been adjusted to a higher setting but does not seem to help.
if your freezer is working your fridge is fine
Your problem probably started a couple weeks ago when the drain that allows defrosted ice (water) to drain into the drain pan at the base of your fridge became plugged for some reason. Then everytime the fridge went on defrost more water melted but did not drain which in turn froze. Now ice has built up and caused the air that flows into the fridge to be blocked, causing a warm fridge.... my advice is to leave fridge unplugged for 48 hrs to thaw it and find the cause of the water not to drain... could be a corn niblet or pea from the freezer... the tube should be visible from the inside or the back
Jul 21, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer temp appears fine - refrigerator temp is 48
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Refrigerators
We have a KitchenAid Side by Side Refrigerator (KSRA25C). The ice maker will not work. We have replaced the "in the grill filter" water valve, but that didn't fix the problem. All other features of the...
Pour about 1/2 cup of water into the icemaker . If it dumps then water valve is the problem . If not , then icemaker is the problem . Make sure the laser switch on r/side of freezer is on . and the coils at the bottom of fridge are clean ( icemaker must be 5 degrees to operate ).
Jul 18, 2009 | Refrigerators
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
32 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
