Question about Pacific Image Electronics Memor-ease Digital Film Converter
Like other users, I get the error message from CyberView CS: "Capture image error. Please restart CyberView CS. If you still have problems, restart your computer. (112: ) I hit "ok" button and get the CyberView screen. When I select "capture" the program freezes. If I select hit "calibrate" I get the error: "Caution! Something has been detected in the scanner. Please remove all films before calibration to ensure the best image quality." But there is nothing in the scanner. I have reloaded software several times. Help please?
3 Suggested Answers
  • 20 Answers
SOURCE: Unreconizable image
Try updating your scanner driver/software to isolate the problem. If same issue still occurring after uninstalling/reinstall, then source of the problem may be a CCD/lamp failure or some sort of dust, lint, on CCD causing calibration failure.
Posted on Sep 03, 2007
SOURCE: The software cannot communicate with the scanner (Prime Film 3600
I have a PrimeFilm 1800u. When I attempt to scan into a Roxio application, the program does not respond. The hardware and software are both installed. No problems scanning or communicating with this scanner before. Is there somethere there that has a soultionfor this problem ? Thanks
Posted on Jan 16, 2011
Cyberview cs memor-ease unable to connect to pc
Try a connecting it to a different port on the computer. Make sure the computer can see a different device on that port, so you know the port is ok. Then try a different cable.
Dec 21, 2013 | Pacific Image Electronics Memor-ease...
My lenovo easy capture camera is not work when i start it the error shown creation of the video preview failed please check the device connection and make sure that the device is not being another...
my lenovo esaycapture your problem is capture image in video the image is down, example yesterday my nephews use program image down, what is the problem and resolve it. Thanks for your help.
Jan 09, 2011 | Lenovo 3000V200 Laptop
It does not recognize my memorease digital slide scanner. I am using windows 7 and the lates drivers from Pacific Image and Adobe elemnts is supposed to see the slide scanner bbut doesn't
If your scanner is like mine, the software is defaulted to look for the OVT scanner. Go into properties and change the default to Cyberview CS Memor-ease.
Jan 15, 2010 | Office Equipment & Supplies
IScanner not communicating w/ PC
If your scanner is like mine the software comes defaulted to look for the OVT Scanner. Go into properties and change the scanner default to Cyberview CS Memor-ease.
Dec 30, 2009 | Pacific Image Electronics Memor-ease...
I have a kyocera cs-1650 with the error message FAX MODE ERROR. can you help?
It is problem Program not properly configure.set up fax program,Fax line type,Receiving mode,number of ring count.Other help follow your copier User Guide manual.If you do not fix your problem then you call a service technician. who support this machine.
Dec 02, 2009 | Kyocera Copystar CS-1820 Black and White...
Trying to use PrimeFilm 1800U scanner on my Dell PC (with Vista), but when running supplied Presto ImageFolio (Mr. Photo) CD, the following message appears: 'String MSG_OS was not found in string table'....
Uninstall Presto Mr Photo, image folio & Cyberview, all of which are not Vista compatible. Obtain new scanner drivers from http://www.scanace.com/en/download.php. Also, can use any image editor once scanning complete. Google provide free application called Picasa at www.picasa.google.com.
Sep 09, 2009 | Pacific Image PrimeFilm 1800u Film Scanner...
Logitech QuickCam Communicate MP - black screen
  1. Either one of these image sizes:
    • Small image size: 160 x 120
    • Large image size: 320 x 240
  2. RGB, I420, or IYUV formats. (Each is fine; we recommend RGB 24.)
  3. Microsoft DirectX version 9.0
To get this information, click here to download a Microsoft application that checks to see if your webcam device meets these requirements.
To make it easy, when you’re asked where to Save the program, just save it on your Desktop.
Once it’s downloaded, here’s what to do:
  1. Double-click the amcap.exe file on your desktop.
    • If you have more than one webcam installed, click the Devices menu and select the one you want to use.
  2. Click the Options menu, then click “Video capture Pin.”
  3. Under “Color Space/Compression:”, choose one of the following formats:
    • RGB 24 (our recommendation)
    • I420
    • IYUV
    Note: If one of the options above isn’t in the list, then your webcam is not compatible with Yahoo!7 Messenger.
  4. Under “Output Size”, choose one of the following:
    • 160 x 120
    • 320 x 240
  5. Click OK
  6. Close the ampcap application.
  7. From your desktop, click ‘Start’ and select ‘Run’.
  8. In the run box, type: dxdiag
  9. In the confirmation dialog box, click OK.
  10. On the System Tab under ‘System Information’, look for DirectXversion. Verify that your version is DirectX 9.0. If it is, just click Exit. If your version is older than 9.0 (any lower number), click here to download the latest version of DirectX.
  11. Start the webcam from Messenger by clicking My Webcam in the Messenger menu.
Attention Logitech webcam users:
Some Logitech webcam drivers may cause one of the following problems:
  • Windows freezes when accessing the webcam
  • A black screen appears when using the webcam in Messenger
  • A ‘Webcam not found’ error message appears.
  • After 3 seconds, the sound drops out of calls made via Messenger
If you already verified that your device is compatible through the above steps and you’re a Logitech webcam user, please click here to update your Logitech webcam driver.
Dec 16, 2008 | Computers & Internet
Unreconizable image
Sep 03, 2007 | Pacific Image PrimeFilm 1800u Film Scanner...
Camera Error in 2mth old Imate Jamin
This happens also because the RAM memory is full by programs opened before. For example, whenever you turn of any program or aplication like contacts or messages, it doesnt turn off at all by clicking the X, it remains opened and you have to go to Star, Set up, then click on Memory, then on running programs, and stop them. This way ram will be able to use the camera and store pics on storage card. Do this also when you see that camera looks like unfocused, its always the ram memory.
Feb 09, 2007 | i-mate JAMin Smartphone
Pacific Image Electronics Memor-ease Digital Film Converter Logo
297 people viewed this question
Top Pacific Image Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Gene Tuck
Are you a Pacific Image Office Equipment and Supply Expert? Answer questions, earn points and help others
