Question about LG 42LC2D 42 in. LCD HDTV
I need a power cord for a lg42lcd ld450 - LG 42LC2D 42 in. LCD HDTV
  • 11,361 Answers
<P>It is the same power cord as used by your PC, NEMA5-15P (15A USA plug&nbsp;to IEC C13 (female Euro receptacle). Any PC/TV repair shop or RS will have them.</P><P>&nbsp;</P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><A rel='nofollow' href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide"><FONT color=#800080>http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</FONT></A><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">&nbsp;<o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><A rel='nofollow' href="http://s807.photobucket.com/home/budm/allalbums"><FONT color=#800080>http://s807.photobucket.com/home/budm/allalbums</FONT></A></SPAN></P><P>&nbsp;</P><P>&nbsp;</P>
Posted on Aug 25, 2010
Does any one know the SKY+ code required for lg ld450 tv?
Hello.
Well first you can try - 065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275, 0206, 0584, 0742, 0851, 1165, 1176, 1208, 1219, 1280, 1293, 1665
if none of the code works for you then please follow the below link to know how to search your sky remote code -
sky.com/portal/site/skycom/skyhelpcentre/producthelp
also check the below link -
skyuser.co.uk/tools/remotecodes/index.php
Good Luck!!
May 07, 2011 | LG Televison & Video
I just purchased an LG TV but no codes instruction book.
LG is prioritized they don't create codes all codes are created by there manufacturers ,to be used with lge products
Apr 02, 2011 | Peerless Industries PL LG42LCD TV
Lg tv wont switch on no standby light and plugged into a working socket
Hi tedwynn967,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the power supply board, try online like ebay.com and shojimmy.com.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Feb 24, 2011 | Peerless Industries PL LG42LCD TV
I have a new LG 32 LD450 TV. When the set is on, there is a green light in lower right. when set is off there is a red light in lower right. should this red light be there all the time, even when set if...
The red light means it's on standby mode but if you wish to turn off the red light you can just go to menu >option>power then choose standby light off.
Jan 08, 2011 | LG 42LH40 LCD TV
I have just bought a LG - LD450 and would like the codes for sky+
Good Luck!!
Nov 22, 2010 | Televison & Video
We have a lg, lcd tv.model#37-LD450, we cannot get our DVD player connected so that it plays, any help would be appreciated, owners manual on a dvd and no use
Your dvd will have a scart socket or a hdmi or other socket, ( check manual), connect lead from dvd to tv, output from dvd to input on tv, from one of these ,on your tv remote select the button that changes the av select , that means the button that tells tv that you want to watch signal from dvd ,( or other input devices) ie sky video camera etc it may be av1 av2 av3, you should get a picture on one of these,
hope this helps
pete
Nov 15, 2010 | Televison & Video
Best settings for my tv
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Oct 13, 2009 | Peerless Industries PL LG42LCD TV
WHATS THE BEST SETTINGS TO SET MY LG TV AT,AS BROUGHT A NEW ONE AND WOULD LIKE THE BEST PICTURE AND SOUND. THANKS
It depends on exacly what you have bought and what you have connected to it. best contact the delaer that you bought the LG from and get them to tell you.
Sep 10, 2009 | Televison & Video
LG 42LC2D 42 in. LCD HDTV Logo
35 people viewed this question
