Question about Whirlpool LSR5132PQ Top Load Washer
When mines done agitating and gets to next cycle hear motor bind and then washer shuts down its a top loader
  • 5,911 Answers
A common cause of the problem you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price of a replacement lid switch is about $25 - $35 if you perform the repair yourself. The lid strike is usually less than $5. Prices will vary between sites so shop and compare.
If you have questions, or need additional assistance, please post back and let me know. These are very simple repairs that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Aug 25, 2010
I don't really have a problem, except that my water bill is eating me alive. Approximately how much water does a full load in my 26912 with one rinse use? And how much water are newer models using on...
Most standard top loading washers have a 35 gallon tub capacity. If you go with a High Efficiency (HE) model washer, which can include the Oasis and Cabrio TOP LOADERS, and the Duet, Elite and Epic FRONT LOADERS, they use about 5 to 7 gallons. High Efficiency washers also do not have a continuous motor in action during agitation or tumble cycles, while most standard top loader have a drive motor that runs throughout the cycle. this can also cut down on the amount of electricity that is used. I hope this helps you.
Feb 17, 2010 | Washing Machines
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Washer will not start rise cycle...it just stops and will not drain.
its the motor. Hopefully you can turn her sideways face down(top loader) and take off the bottom plate. If you have a belt driven motor your in luck. slip off the belt.....disconnect the water hoses and plu it in face down. turn only on spin cycle.
If the motor don't spin...search ebay..done.
This is standard for all washing machines except for the plastic driven drive shafts.
Also you might want to check your PUMP which has two hoses. Take off the pumps and see if there hairs in there. Remove if you can. Some pumps are one piece(buy replacement **** shell that you can unscrew) remove hair put back together. done.
100% motor binding problem ...if you cant pump water out(small motor and pump clog) Fix the clog your good to go. 20 mins tops.
Aug 17, 2009 | Whirlpool Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Washer continues to spin slow in the last spin cycle.
Red Ryder, the motor is 1 speed on this model. A couple of things to check; one would be the belt. Look for shavings, cracks or if it's shiney, could be worn. If your p number is p1118410ww, looks like you have 2 belts, agitate and spin and pump. Pump-R0606507, spin-R0606539. Check the pulley, make sure it is not binding, lube it up, and check the pump, something might be binding there. As long as you don't have a grinding, howling noise during spin the bearing should be good. Catriver..post back.
Feb 20, 2007 | Amana NAV5800A Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
