Question about Konica Minolta PagePro 1350W Laser Printer
Some times the paper will not be fed through to be printed. The roller doesn't always pick up the paper. When that happens I have pick up the paper and feed it through manually. I believe that when I put more paper to fill it up the roller won't have to drop so low to pick up the paper. I guess what I'm saying is that it make be the roller is bad or I just have to keep the paper feeder full at all times. Hope this will help you to determine my printer problem Thomas, KY
  • 61 Answers
Use a paper towel and some isopropyl alcohol if that fixes the problem you should get an extra roller because they do wear out over time
http://www.precisionroller.com/search.php?q=+konica+minolta+pagepro+1350w++roller
Posted on Aug 25, 2010
Doesn't pick up[ paper
Possible that the intake detect or the pick in rollers are not aligned properly . You need to check the opto-couplers and the roller settings.Remove and check with a paper to see the uniformity of the gap between the rollers.
Jan 20, 2012 | Samsung ML 1610 Laser Printer
Ink there. My printer does not pick up the paper fron the tray. It only picks it up when I use thick paper and I help it with pushing it into the machine. Always the smart panel telling me there is a paper...
The pick-up roller at the rear of the printer probably needs to be cleaned using an alcohol solution as over time it picks up dirt and ink from the paper being fed through the printer, especially if printing on both side by turning the sheets over.
Oct 27, 2011 | Samsung CLP 300 Laser Printer
Our infoprint 1125 is on a ibm mid range computer system & is accessible to 9 users. when we print an envelope, the printer asks for a manual load of the envelope, how do i change this to automatic...
It's been my experience with these machines that envelopes are always fed through the manual feed tray.
The Tray 2 cassette's pick up assembly is different than the manual feed,
it has 2 rollers that have a wide area they can pick up while the manual feed has just 1 single roller.
If you remove the tray cassette and look under the printer you can see the two rollers, these would probably have a hard time picking up a standard size envelope.
Also the tray would have to path the paper up and would have to bend it through the paper path which can cause problems with the flaps on the envelopes.
Best method is to use the manual feed tray and to also have the back cover open so that the envelopes path straight through the printer without being curled.
(I've seen these in a ton of places ranging from small business to banks and they always have the envelopes in the manual feed)
Jun 08, 2011 | IBM Infoprint 1125 Laser Printer
Not picking up paper
Most new printers and copiers will attempt to feed paper several times before failing and giving a jam condition. It sounds like that is what is happening to your printer.
Your tray rollers may be dirty. Remove the tray and use a clean cloth with mild detergent to clean the rubber rollers. Do not use alcohol this will dry the rollers out. If problem continues replace the tray rollers.
May 18, 2010 | Samsung CLP 300 Laser Printer
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
steps:
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
Hp 4345 printer that is picking up multiple sheets from tray2
Frankly speaking, this problem exists and printer companies always have denied this. What I think from my experience that there is some engineering problem with all these printer, in the way paper is fed in.Still I give some solution which HP's site suggests. See if it works in your case:
Issue Multiple pages feed through the printer when printing. Solution If the printer is picking up multiple sheets of paper, follow the recommendations below:
  • Keep more than 10 sheets in the In tray.
  • Ensure media is not loaded too far and extending past the In tray.
  • Store all media in a dry, cool place. Humid climates will see this issue more often.
  • Do not print on media that has already been printed on. The dampness of the ink will cause pages to stick together.
If the printer continues to pick up multiple sheets of paper, follow the following troubleshooting steps below:
  1. Remove the media from the In tray.
  2. Fan the edges, re-square the media, and reload the media properly into the In tray.
  3. Slide the paper width guide to the right until it stops at the edge of the media, then push the paper length guide towards the paper until it stops.
  4. NOTE: Not all HP Deskjet printers have rear access doors. Skip this step if your printer does not have a rear-access door. Remove the rear-access door (if applicable) and clean the internal rubber rollers with a soft lintfree cloth moistened with distilled water. Wait until the rubber rollers dry and replace the rear access door.
  5. Verify that the correct media size and type is selected in the printer settings along with the appropriate quality.
  6. If this issue still persists, try a different type of paper.
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=gb&dlc=en&docname=c00190540
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Jan 26, 2009 | Office Equipment & Supplies
Canon Imagerunner C3200 - printing problems
check the feeder rollers and make sure they are grabbing the page at the right time. Sometimes rollers cna get slick and spin for a moment before picking up the paper. This can cause the timing to be off when the page is fed through.
Mar 06, 2008 | Computers & Internet
Out of Paper
It sounds like your paper sensor is defaulting, or you could have foreign material blocking the paper from loading so the paper sensor can pick it up. Check out this first and repost if not the problem. Thoroughly check inside unit and down the back for blockages or debris.
Apr 12, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Paper sent through without printing
You should try cleaning the pick up roller. It may be your paper has quite a dusty surface and this will cling to the pick up roller making it less grippy. When the paper is fed it may not make the first sensor in the expected time and thus creates the error. Get a service manual to show you how to get a t the pick up roiller so you can remove and clean it. You can get Platen Cleaner from many web sites and it is specifically formulated to regain friction os such rollers. Try either: http://wwwTheServiceManualShop.com or http://mikeburton.tradebit.com/ for a service manual
Apr 11, 2007 | Epson Stylus Photo R2400 InkJet Printer
Konica Minolta PagePro 1350W Laser Printer Logo
138 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
