Question about Crosley Washing Machines
I have a Heavy Duty Washer Model No.CW6000W Rev 12 Serial No.12835368ZY Part that Turns back and forth to Wash the Clothes has detacted from the lower part of the washer that helps it to go back and forth and spin when rinsing and the part where U put the fabric softner My E-mail is Dianne Walker@Verizon.Net
  • 11,896 Answers
The part that spins back and forth is the agitator.
Step 1: Turn off the electricity to the washing machine at the main circuit breaker. Pull out the appliance and unplug it.
Step 2: Turn off the water supply valve to the washing machine, then disconnect any hoses from the washing machine and drain them into a bucket.
Step 3: Open up your washing machine and pull out the top of the agitator, leaving the actual agitator exposed. Locate the screws that connect the agitator to the rest of the washing machine. Using a screwdriver, tighten these screws firmly, making sure that they are not allowing the agitator to wiggle while in motion. Close the washing machine.
Step 4: Detach the back panel from the washing machine, exposing the belt that connects the agitator to the motor. In most cases it is the only belt accessible from the back panel.
Step 5: Look at the belt carefully. If there are signs of wear, splitting, or worn spots, buy a new washing machine belt and replace it. To do this, you must loosen the bracket that connects the motor to the washing machine. With the motor loosened, move it closer to the opposite pulley and remove the washing machine belt. Attach a new belt over the two pulleys, then stretch the belt to allow the motor to resume it's previous location. Tighten the bracket holding the washing machine motor.
Step 6: If the washing machine belt is in good condition, but has a lot of give in it, loosen the motor bracket slightly and move it further away from the opposite pulley. The ideal give to a washing machine belt is about ¾ inch, so don't over tighten the belt. Tighten the bracket to hold the motor into it's new location.
Posted on Aug 25, 2010
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Front load washer, try to spin, but stops altogether and want wash it fills up but want wash
Make sure that you don't over load the washer. As it starts to spin back and forth it is sensing the load balance as the clothes fall back and forth. If it doesn't sense a balanced load because the clothes can't fall back and forth it will not start the wash process. Refuse your load and try again.
Oct 16, 2013 | Frigidaire GLTF2940ES Front Load Washer
I have a magic chef 20 lb capacity heavy duty washer model W20HN3S serial ME851474 with spin problems. Clothes come out soaking wet. Can I replace a belt?
If your washer will wash (agitate) your clothes but does not spin well, you will need to replace the "thrust bearing" in the washer. The repair is simple and will only take you a short to do. Here is a link to the "thrust bearing kit" you will need.
Jan 07, 2011 | Chef Cooking Magic Chef Washing Machine...
Kenmore model 8662100 heavy duty what year is it and is there still parts available for it?
Please post back with your COMPLETE serial number (usually located along the wash tub rim under the lid) to include any letter designations. This determines when the appliance was manufactured. The model number you provided crosses to a dryer. If this is a dryer, the serial number will be find along the door opening. Please confirm your model number as well. The number should begin with a "110" prefix. You listed this as a kenmore heavy duty...and listed it under washing machines. If this is a washer, I will need a more accurate model number (if possible) to be able to determine part sources for you.
Jun 29, 2009 | Washing Machines
Kenmore Washer
I had our washer repaired several years back and the guy said it was a problem with this model and we should NEVER use any cycle but the heavy duty. The only way to reset the machine was to let the machine run through its cycle one time (stopping and starting). Once it completes - everything goes back to normal unless somebody decides to switch the wash action to something other than Fast/Fast.
Sep 22, 2007 | Washing Machines
Washing Machines Logo
62 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
