Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I tried washing a load of whites and when the machine gets too 62 minutes remaining, the dial flashes LF and the bleach is not draining down.
    Brigadier General:
  • 8,619 Answers
Thanks for using FixYa. LF error means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 26, 2010
WATER & SOME OF THE BLEACH DOES NOT DRAIN FROM THE BLEACH COMPARTMENT AFTER EACH WASH? HAVING TO PULL DRAWER OUT & EMPTY REMAINING BLEACH & WATER EACH TIME BEFORE NEXT USE. WHAT CAN BE DONE?
Your washer is designed to purge the bleach dispenser between loads. For example, if changing from bleach to no bleach. The residue is normal.
Apr 27, 2016 | LG WM2487H Front Load Washer
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
May 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Jul 20, 2009 | Washing Machines
Whirlpool Cabrio washer is leaking water
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Bleach remains in bleach dispenser after washing and even after extra rinse cycle
I put the bleach in with the load right on top of the whites, so I dont have bleach left in the dispenser for the next load. Seems to work okay.
Jun 02, 2009 | LG WM-2277HW Front Load Washer
Bleach ruins colored load done after white load
Your bleach dispenser is the problem. It needs to be replaced. All of the bleach isn't leaving the dispenser so when you go to wash your colored clothing what's left in there comes out. Best thing to do till you fix it is wash your whites last. You can try running some white vinegar through the wash on the hottest cycle. Pour the vinegar into the bleach area and the soap area and run it on hot. Run it a couple of times. If there is anything clogging up the dispenser this might clean it out. Let me know if you have any other questions and good luck.
Oct 18, 2008 | Whirlpool GHW9300 Duet Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Liquid Bleach dispenser doesn't work correctly
This may not be relevant, but by design, bleach does NOT dispense in the Buly/Bedding, Kids Wear, and Silk/Ultra Delicate cycles. If you try to use it, it remains in the dispenser.
As for the yucky smell, leave the door open when not in use.
Nov 16, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
White Clothes even with bleach and hot water don't get clean???
i have used everything to solve this exact problem!  I have to say the best detergent or bleach i have used in the lg..is the purex with bleach for colours it seems to work better than anything ive used...spent a fortune to have to soak my whites before putting them in this washer.  I must say im disappointed..
May 06, 2007 | LG WM1814CW Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
32 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
