Question about Infogrames Dig Dug for Windows
DigDug Deeper will not play on windows 7.. tried everything and can not find a patch for windows 7... anyone get it to work
Why cant i play zoo tycoon 2?
Method 1.
Let us first download and install the patch for this game and then try playing and check if it works.
Here is the link to download the patch.
http://zootycoon.com/Downloads/patches.htm
Method 2.
If you are unable to play the game or install the patch perform the below steps.
a. Click start and type msconfig in search bar and press enter.
b. Select boot.
c. Go to Advanced options.
d. Place a checkmark on Check maximum memory and increase it to the maximum.
e. click ok and the apply and ok again.
Method 3.
Try playing the game in clean boot state and check if it works.
Refer to the article below for steps about how to start your computer in clean boot state.
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
Note: When the troubleshooting is over do not forget to reset the computer to normal startup. Follow the step 7 in the above article.
Hope this helps.
May 15, 2012 | Microsoft Zoo Tycoon 2: Zookeeper...
I have age of pirates caraibean tales but i just cant play it on windows 7.What should i do?
You need to patch it to work with Win 7. This should do it:
http://games.softpedia.com/progDownload/Age-of-Pirates-Caribbean-Tales-15-Patch-Download-12782.html
Just remember to download with care :)
May 07, 2011 | Atari Age of Pirates: Caribbean Tales for...
How do i run medieval lords on windows 7 ? please help im dying to play some classics
Here is how I managed to get it to work on Windows 7.
Download the patch at www.gspsupport.co.UK/media/patches/Medieval_Lords.exe
1. Save the file Medieval_Lords.exe to your desktop
2. Right click on the Medieval_Lords.exe on your desktop and left click 'Cut'
3. Go to C:\Program Files\Monte Cristo\Medieval Lords\BIN
4. Right click in this folder and left click 'Paste', this will ask you to replace the Medieval_Lords.exe , click 'Yes' .
5. Go to C:\Program Files\Monte Cristo\BIN\DATA\SHADER
6. Rename the file named StdMatDX8.fx.bin from "StdMatDX8.fx.bin" to "StdMatDX8.fx"
7. Run program as administrator
Hope this helps
Jan 18, 2011 | Monte Cristo Medieval Lords for Windows
Singer CE-200 Quantum Futura
There is a patch for Windows 7 at www.future-support.com. That site is an amazing resource for the Futuras!!
Apr 14, 2010 | Singer CE-200 Quantum Futura Computerized...
I am using windows 7 64 bit...i have downloaded the free trial version or arcsoft dvd slide show..everything works up untill step 3..the remote is there to preview my slide show, but under the options for...
well first check whether your dvd rom is shown in my computer and is it is there try to burn a dvd using windows dvd maker using some vido files if this works you better download the new arcsoft dvd slide show tha is compatible with windows 7 64bit edition cuz it needs special software
or try thease software patches from the vendor site the say they are windows 7 compatible just read and download them you do not need to unistall your current version
http://www.arcsoft.com/en-us/download_patch.asp?id=1
try it and please rate...
Apr 11, 2010 | Arcsoft DVD SlideShow for Windows...
C&C Generals Zero Hour problem play on windows 7 64bit
Try patching the game, think that was a known issue and had to be resolved by actually patching the game. Also sounds like you might be playing a skirmish instead of missons, check what your doing. If you set up everything in the beginning such as who you fight against, your playing against the CPU and not actual missons.
DrakeTech.
Mar 01, 2010 | Electronic Arts Command & Conquer:...
For Singer Futura CE 250. New laptop with windows 7? Loaded software & tried 64 bit Vista update patch - it doesn't work. Is the newer patch available for download? Can't use Live Update because...
Update with WIndow 7 support is already available at:
http://www.futura-support.com/downloads/ce150.html
If you applied wrong patches you will have to uninstall Futura, reboot, install from the beginning the basic version and then apply an update 3.0.0.9
Jan 03, 2010 | Singer CE350
Mirophone problem in window 7100
Using the Windows 7 Beta is meant to be a test version of the upcoming operating system, not a fully functional version. If your microphone cannot be heard on the other end, try downloading drivers for the microphone. If this does not work, try submitting a bug report to Windows to get a patch made to fix this issue.
Keep in mind, you are using a beta opersating system and your expectations should not be that of a stable release. Things are meant to break.
May 24, 2009 | Microsoft Windows XP Professional
Olympus vn-2100pc
check out this link, i had exactly the same problem but this blogger has a working patch for the vn-2100pc and vista - works fine now!!
http://blog.ironguard.net/2007/06/olympus-vn-2100pc-and-windows-vista.html
Sep 13, 2007 | Olympus VN-2100PC Digital Voice Recorder
Infogrames Dig Dug for Windows Logo
50 people viewed this question
Top Infogrames Video Game Consoles & Games Experts
newclique
Level 1 Expert
Carlos L. Burgos
Carlos L. Burgos
Terry Hair
Are you an Infogrames Video Game Console and Game Expert? Answer questions, earn points and help others
