Question about Hoover F5872-900 SteamVac Wet/Dry Vacuum
My Hoover stopped sucking! If I use the attachment for stairs that works just fine, but in the upright mode for carpet it won't **** at all.
  • 694 Answers
The tube in the power head probably has either a clog or a leak/crack. Since the hose attachment works fine, then the hose should be clear. You may be able to clear it without much difficulty, but replacement should be done at the Hoover shop.
Posted on Aug 25, 2010
When hose is attached to Hoover Spin Scrub 50 sucking and solution come out fine but solution is also pouring out the bottom of Hoover
Hello! Make sure that the cleaner is in the upright position when you are using the hose. This ensures that all solution goes through the hose and not the cleaner. Be sure the black tabs on connector coupler are pushed out prior to inserting into the stair cleaning connection. If you have done this and the cleaner is still leaking, we recommend taking to an authorized repair center for service. Follow the link to locate a service center near you.
Service Center Locator
Hope this helps!
Sep 01, 2014 | Hoover Spin Scrub 50 Deep Cleaner
Why does The beater bar on my hoover continue to run in the upright position?
Hi there! Some vacuums do not come with the feature that automatically shuts the brushes off when in the upright position.. If your unit is like this, be sure to put the vacuum on the highest setting when using the hose. Also, because the brush-roll continues to spin, avoid tipping cleaner or setting it on furniture, fringed area rugs, or carpeted stairs during tool use. Hope this was helpful!
Jul 21, 2014 | Hoover Vacuums
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My attachments won't ****
Hi
If the machine is picking up from underneath the hose must be blocked. Try dropping a coin into the hose and see if it comes out the other end
Rob
Feb 13, 2009 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Carpet vacuum attachment quit working after sucking up a bedskirt. Bedskirt has been removed but carpet attachment will not work. My old vacuum had a reset button on the carpet attachment for use when...
I have a Hoover Conquest approx. 4 yrs old. The turbo head is not working Model No. PB4 230-240V AC 50Hz 200w CS4901N (N127) I have been trying to locate another one or another one similiar to fit my machine
Jun 12, 2008 | Hoover Vacuums
Motor not turning
Don't forget, the agitator bursh doesn't work when the vacuum is upright. Maybe that is your problem.
Apr 01, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Can't get it to **** up water from the carpet
Check the filter on the bottom side of the lid, make sure it has at least 1/4 inch gap from the top of the filter to the to of the lid. Is the lid secured all of the way around and not loose on the back part of it. Is the duct in place in front of the tank?
Mar 28, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Stair attachment has weak suction
Did you put the duct in for the hose? It goes in front of the tank, take out the duct (#3)that is there and put in the duct that is on the end of the hose. Is there a slit somewhere in the hose, if so you will loose suction.
Nov 17, 2007 | Hoover F5826-900 SteamVac Upright Wet...
Hoover F5872-900 SteamVac Wet/Dry Vacuum Logo
102 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
