Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
I have a Kenmore 18 refrigerator (freezer on top). When we open the refrigerator door, water drips down from the inside door panel.
  • Mike Smith
    Mike Smith Aug 25, 2010
    need COMPLETE model number to help .
  • 86 Answers
Hello
Check you door and door gasket to make sure you have a good seal. What happens is warm air and moisture is getting in and condensing on the panel. I hope this helps. Please leave feedback. Thanks
Posted on Aug 25, 2010
Where can I access the defrost drain hole in my Kenmore model 253.74879404 Refrigerator? Disassembling the freezer did not work.
I've used used a compressor for that drain hole at the back of the fridge. A hanger wire will work too. I've never tried it but maybe a can of compressed air might work also.
The water drain line is plugged and that little catch tray is overflowing. That's why you're ending up with water under your bins inside the fridge. The problem is not in the freezer or else you'd have a skating rink on the floor of the freezer.
I don't recognize the photos exactly but they're all the same principle. Take everything out of the fridge , including the racks. It's far easier than o find the screws and disassemble the drain "catchall".
Good luck.
Dec 18, 2014 | Kenmore Refrigerators
Water dripping from freezer into refrigerator
Hi,Most likely the drain in the freezer is clogged up and frozen. Every time when your fridge automatically defrosting defrosted water dripping inside the fresh food compartment. You have to remove the back panel in the freezer and using a hair dryer defrost the drain which is located under the evaporator coil. Then put very hot water through the drain until it goes free.
Yes, you need to remove the back panel inside the freezer, It should have screws that come out then it should pull off and out.
On your model, the defrost drain hole/line is located inside of the freezer behind that back access panel, just remove that back panel, remove your freezer floor panel FIRST(Has 2 screws in front), that simply pulls out, then you will see the drain hole under the evaporator coil. It may be iced up, you will have to clear all of the ice and run hot water down the drain hole.
Once the back panel screws are removed that panel should just pull off, pull hard. Make sure your refrigerator is unplugged first.
Good luck.
May 28, 2011 | Kenmore Top Freezer Refrigerator
Water dripping into refrigerator from freezer
Drain in freezer is clogged usually with ice. Unplug frige and defrost 6 hours with doors open. Pull lower front grill and check drain pan for water. If no water remove rear panel inside freezer to clear drain hole, below coils in the middle...
Mar 29, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
There is a drip inside the refrigerator. I shut off the water supply for the ice maker and it is still dripping. Now what?
your defrost drain is clogged with ice. Its not clogged for any other reason than ice build up covers drain hole. empty your fridge, turn off and open both doors, blow fan for 24 hours to clear out all ice. this is a common problem with kenmore top freezer models. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Water drips inside the refrigerator
That usually means your drain in the freezer is clogged or frozen. You will have to take the evaporator cover off to see the drain hole at the bottom in the middle. If it is covered with ice remove the ice by letting it thaw for a couple of hours unplugged and door open. Should be able to remove excess by hand.
Sep 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water inside refrigerator
Even though it doesn't seem like it's coming from your freezer, morre than likely that's where it's coming from. At the back of the fridge there will be a drip tray that actually catches the water from the thawing freeze. One way to avoid access water is to simply turn down your freezer and fridge. Usually if they are number 0-10, both frigde and freezer should be set on the 5 level.
Aug 31, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping from freezer when defrost kicks on.
You probably have a plugged drain in the freezer compartment. Open that up and check it. Hope this helps!
Feb 16, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore upright fridge--freezer door drips when cleaning
Condensation has formed and frozen behing the door panel. You can live with it, or take apart the panel and dry it out - you may have to replace some insulation. Hope this helps!
Feb 07, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
