Refrigerator stopped cooling - Heating & Cooling
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 05, 2008
Why would the lg r410a start cooling then stop?
If its low on refrigerant, the low pressure switch will drop out the compressor. If it has an extremely dirty condensor, the high pressure switch will drop out the compressor. If it has a bad condensor fan, the high pressure switch will drop out the compressor. If the internal overload of the compressor is weak and it is marginally low on refrigerant, the compressor will stop until it cools down. The list goes on and on and on.... These are the first four most obviouse that comes to mind.
Jan 31, 2015 | LG Heating & Cooling
GE ptac won't stop running
heat or cool mode. most have a freeze protection keep room from freezing. or in cooling may need a tech support walk thru the codes if electrical/thermostatic issues. worse case refrigerant.
Jun 24, 2014 | Heating & Cooling
My A C conpressor is cycleing realy fast, every few min. would it be the conpressor capacitor ?
No. It is "short cycling" probrably because it is low on refrigerant which means there is a leak somewhere. The refrigerant cools your compressor windings. If it is low it cannot cool the windings and it will stop the compressor due to a temp overload. As soon as the compressor cools back down it closes the bi-metal switch and allows the compressor to start again. The cycle will repeat itself until the compressor finally quits. Hope this helps.
Please rate my response on FixYa.com
Aug 03, 2011 | Dometic Rooftop RV Air Conditioner
Haier Mini spilt HSU18VC7 compressor runs for 5 minutes then stop 3 minutes then run another 5 minutes and so on.
This is called short cycling. It sounds like the compressor is getting hot and opening a bi-metal overload, which shuts the compressor off. The compressor cools, because it is not running and the bi-metal contacts close allowing the compressor to start again. This will repeat itself and is usually due to low refrigerant, which usually means there is a leak in the normally sealed refrigerant lines. The refrigerant cools the compressor windings and if it is low it cannot do that, hence the shutting off of teh compressor, cooling down process and restarting of your compressor. Short cycling will ultimately ruin the compressor.
If this has helped you please give me a rating worthy of my diagnosis.
Aug 03, 2011 | Haier Heating & Cooling
Refrigerator is not keeping cool and frost is collecting on evaporator coilwould the be because of bad defrost timer
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 15, 2011 | Heating & Cooling
My kenmore window unit AC started blowing a white smoke like substance. It seems to be cooling fine. What is this and is it a concern?
The two things it could be, #1 - evaporator leaking refrigerant - unlikely if unit is still cooling o.k. because window units do not hold a lot of refrigerant and if there is a leak bad enough to blow smoke it would have stopped cooling by now. #2 - the humidity is high and the unit has cooled the air right at the discharge down below the dewpoint, a common occurence in window units and automobiles due to the short duct distance from the evaporator to the air outlet whereas with central air systems having longer duct systems the air gains more heat before being discharged into the room.
Aug 26, 2010 | Kenmore Heating & Cooling
Coils stop feeding intermittenly not always the same circuit
You could have a solenoid prblem or just low of refrigerant. Need a qualified service tech to check charge. Rusty
Jun 03, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
A/c wont cool despite 2/3 cans refrigerant
A failed compressor can cause this problem, including having a leak that can not be patched with leak stop.
After you turn on the A/C unit, does the compressor "kick in" within a minute of turning the unit on? Do you hear any "clicking" sounds? If yes, post back here and we can take the next step.
May 08, 2009 | Heating & Cooling
Water stop dripping less cooling
Your aircon probably needs refrigerant recharge.
Jan 29, 2009 | Heating & Cooling
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
