Question about Hayward SAND FILTER, PRO SERIES
How to hook up vacuum to sand filter - Hayward SAND FILTER, PRO SERIES
  • 819 Answers
Hooking up the vacuum assembly is done at the poolside skimmer. there is a vacuum plate that goes over top of the skimmer basket, allowing you to leave the basket in place to catch any larger debris. the plate will have a fitting at the top to attach the vacuum hose. before turning the pump on, be sure to bleed the air out of the vacuum hose so the pump does not run dry.
if this is a new thing for you (like you just bought the house with the pool, or something like that), please post any further questions in the comment section, i realize this can all be sort of overwhelming at first, and often the previous owners don't leave you all the pieces you need!
Posted on Aug 25, 2010
  • Austin Riley Jul 01, 2013
    i do not have a skimmer on my pool but is it still possable to atach a vaccum or would i have to buy a skimmer
My Hayward sand filter vl40t32 will not vacuum. It is only 1 season old, and I have never gotten it to vacuum. It does, filter, but not pulling the water for vacuuming...
Before you hook up the vacuum attachment, you want to flood the vacuum hose with water or your pump will be air locked. Submerge the hose and fill it with water. These centrifugal pumps must be primed in order to work. Another method is to fill the vacuum hose with water from a garden hose.
May 27, 2017 | Hayward Pool & Spa
Tip
How To Connect Hook Up Use Above Ground Swimming Pool Vacuum and Hose With Sand...
<utube src="YEW-QUyP2Iw"></utube>This video will show you how to connect your above ground pool vacuum and hose to the sand filter on your swimming pool.
on Aug 03, 2013 | Pool & Spa
70110 sand filter. how do I connect a vacuum hose?
hook up to your skimmer over the basket to catch leaves
Jun 24, 2015 | INTEX Sand Filter Pump
Sand filter not filtering! It's been 4 weeks of
Air enters from the front of the pump, usually it is just the lid o-ring (over the pump basket) that needs to be lubed or replaced.
Sand filters do not filter fine particles very well. When vacuuming it is best to set the backwash valve to the "waste" setting. This allows the debris to bypass the filter and go directly to waste. Mind that you are removing water from the pool while on that setting.
Jul 07, 2013 | Pool & Spa
I have 7 year old Hayward ProSeries, S-244S, H/R Sand filter. I've notice that when I vacuum the pool, dirty water returns to the pool. I've backwashed and the spider gasket is fine. No sa
sand filters only have limited filtration. If the dirt is very fine such as dead algae, it will go right through the filter. Use a clarifier to help give the filter finer filtration. Do not vacuum until you can see what you are doing, then vacuum on 'waste'
Sep 19, 2012 | Hayward SAND FILTER, PRO SERIES
Low water pressure coming out after pump is on
Check skimmers, pump strainer basket and filter pressure. If filter pressure builds. time to backwash the filter. Also, the impellar on the pump might have debris in it...
Jun 06, 2010 | Hayward SAND FILTER, PRO SERIES
Will a 240 hayward sand filter with the SPX0710X32 valve, allow
If they are to much for the pump basket you can try filter by-pass. Another thing could be a tool called a leaf master that hooks on your garden hose and sweeps any and all light stuff from pool and collects in a bag big enough to hold it all in one sitting.
May 27, 2010 | Hayward SAND FILTER, PRO SERIES
What setting should I have my Hayward Sand Filter system on when I am vacumming out my pool?
Your pool filter should be set on "filter" for normal vacuuming. If you have a heavy debris load or an extremely dirty pool, you might want to vacuum with the "waste" setting, if your filter has one.
May 20, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
697 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
