FixYa.com
Tags:
Microsoft Windows XP Professional for PC
Installing windows xp 2006 with service pack 2
posted by humnesa on May 05, 2008
hi , i want to format the pc and to install from boot up but there is no command which say" touch any key to boot from cd" and there is no change on the pc ( cd drive doesn't turn) but when i change cd that means similar windows cd the command prompt is seen. please tell me the solution , thank you very much.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 05, 2008
FixYa! (100)
melnavz
Rank:Wiz Wiz
Rating: 85%, 447 votes
You should set the first boot to redirect to the cd ROM boot.
Go to the bios setup by pressing " F2" or "DElete" and first boot.
In there find the boot sequence or boot order something like that and set it to cd rom (pls follow the screen instruction when selecting some option) . after selecting the boot order press "F10" to save and exit.
some PC you can select by pressing "F9" and the first boot and you will be directed to the boot selection automatically.
may this help:
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 10, 2008
Helpful (85)
sachin patil
Rank:Master Master
Rating: 75%, 6 votes
when u insert the cd press shift-tab.it will detect ur cd.if it don't then change the cd ur installing xp with
Can you Help with these Operating Systems problems?
E/archive RUNDELL
como lo arreglo es un programa... Answer This...
Operating Systems
vb programming
find the Furure value of an... Answer This...
Operating Systems
My Sandisk Sansa e250r keeps...
I have tried many things to fix... Answer This...
warcraft 3 frozen throne
Hello, I just got warcraft and... Answer This...
Wireshark
http://www.wireshark.org/ Im... Answer This...
Repair Service
Find Operating System Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
