Question about Fujitronic FH-778 Air Conditioner
Where do i put the water at??? - Fujitronic FH-778 Air Conditioner
How to activate a 10 cup bunn coffee brewer model nhb?
I don't understand the question, but here is a try.
1 - put in two pots of water.
2 - put in third pot, the water should start coming out
Allow the water to heat (thirty minutes) then put coffee in filter housing, put in one pot of water, put empty pot on warmer, close lid, wait for brew cycle, enjoy coffee.
Feb 27, 2015 | Bunn 10 Cup Home Coffee Brewer
Losing water and running hot.water is not leaking out onto ground.just have to keep putting water in car
Ur car is having a clogging water pump or a dying water pump problems.The car water pump it is not doing it job like circulation of the water in the car through out the car engine evenly.The car keep losing water that u keep putting it in because of the car engine keep overheating and causes water candensation and evaporation of the water u keep putting it into the car.This car must have be check out by an auto mechanic for changing it holes systems on the car water pump or must have be do a replacement of the whole water pump unit itself.
Sep 28, 2011 | Cars & Trucks
How much water to put in the water entering tray
dehumidifier's remove moisture from the air,so you really don't want water anywhere close, the tray in a dehumidifier is to collect water removed from the air. a humidifier is easy, you put a pan of water close to a heat source or moving air
Jan 31, 2010 | Dehumidifiers
I put water in after it was already brewing
This should never happen - when it's low on water it'll light the "fill water" indicator and not brew until it's filled - if you managed to somehow run a brew cycle with no water, then there is something wrong with your brewer.
Jan 16, 2010 | Keurig Elite B40 Coffee Maker
Water pump
Hello drain the water from the radiator by removing the hose from the radiator to the water pump,after having taken out the hoses,then unscrew the bolts that hold the water pump.After having taken the pump,clean the surface where the pump is fitted on the engine.Now when putting,the new pump,put a clear layer of silicone gasket on the surface where the pump will fit to prevent leakage,now you screw the bolt to the same torque,then after put the hose back like it was before,fill your radiator ,do not put the cap now,because of an air lock in the water circuit,start the engine,you will see the water level lower,fill it to its level,then put the radiator cap.Hope that help you in changing the pump,good luck
Dec 26, 2009 | 2000 Nissan Maxima
I don't have instructions for the Rainbow shampooer. I'm not sure how much water to put in, or whether I put water in both reservoirs. Does anyone know?
Water only goes into the cub in the handle. The dirty water gets put into the bowl on the canister part.
Nov 28, 2009 | Rainbow Vacuums
Where do you put water in it?
The manual for this item is available here:
http://useandcaremanuals.com/pdf/C520695.pdf
You put the water in under the water cover located above the steam button.
Nov 25, 2009 | Black & Decker Gizmo C520 Iron
Water pump
buy a new water pump, remove the radiator, remove the hose from the pump, remove the bolts that holds the pump, remove the old pump.
put the new gasket in the pump, dont forget to put a little bit of grease just to hold the gasket inplace. put the new pump, use the old bolts from where they are taken ( sometimes they are not of equal length ). if you have a torque wrench then use it to tighten the bolts with equal amounts of torque. put the hose back, put the radiator back, put water in the radiator, run the engine and look for some leaks at the new pump.
i hope i did it..
tnx, drcool
Jul 28, 2008 | 1998 Chevrolet Cavalier
Fujitronic FH-778 Air Conditioner Logo
15 people viewed this question
Top Fujitronic Heating & Cooling Experts
Bill Long
Jay Finke
Jay Finke
Are you a Fujitronic Heating and Cooling Expert? Answer questions, earn points and help others
