Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Inputs are not working menu screen comes up but no inputs just installed new board is there some thing i need to do after so it gets reognized?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
No inputs showing? which board did you change?
There are a few choices here---set does have a hard reset which I can tell you how to access with remote----It is the Option menu--it will allow to reset set to condition it was in when new in box.
Set will turn off, come back on on channel 3 in Air band---
If this information was helpful and you want to know how to get to the Option menu rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 25, 2010
HAVE A SAMSUNG UN60ES6100 LED AND HAVE BLUE SCREEN WITH NO VIDEO EVEN NO MENUE, REMOTE WORKS CHANGE VOLUME BUT CANT SEE AUDIO BAR JUST BEEP GOES UP AND DOWN, TRIED NEW MAIN MODULE AND SAME TROUBLE. T
Check all the flat cables runs between main board and T'Con for and damage or loose contact at both ends. If all are found OK, check the set with any external input; like CD player or VCR. If you do not get any image on screen with these inputs too, its T'Con board is faulty. If you do get images with external inputs, and not with RF or Cable inputs, the Tuner section circuit and the AGC alignments should be checked. In most cases, a main board replacement might need a firmware update too.
Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2014 | Samsung UN60ES6100 60 LED-LCD 1080p HDTV
White screen on television/no picture
White screen on TV means that no digital signal is coming from:
1: inputs or
2: TV signal
Generally the problem comes from the wires on the back of the LCD/LED is disconnected. But can also mean the the digital output board has failed or is damaged. If you cannot get the digital setup menu on the screen you will have to have the board replaced at a shop. One thing you can try is to Plug in TV while holding the power button. Sometimes that will do a factory reset. You did not indicate Brand or Model and cannot provide any more tips.
Nov 27, 2013 | Televison & Video
Sony KDL42V4100 - No picture (and no menu), sound only?
There could be several things that can cause this. Could be a bad CCFL bulb, inverter, power supply problem, main board, or T-con. You will need to have the set diagnosed to track down the problem.
Aug 30, 2012 | Sony KDL-46S4100 46 in. LCD TV
My 2003 Sony Plasma television gets no screen. I was watching television when the image froze. I turned off the television, and turned it back on. I can hear the audio from the cable, but I get no picture....
Check all the video inputs. If non of the inputs of video work you need a new Q board, However if your screen doesn't work at all shows no signs of life and you can't access the menu then you will need a new B board.
Oct 30, 2009 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Philips Tv always returns to menu screen
ssb board failing need to be replaced encompass.com
Sep 17, 2009 | Insignia 42" LCD Flat-Panel HDTV
Vizio lcd sreen fading out.
Well time will tell if this is a true solution but I experienced the same issue. Originally I was able to get the TV to work by turning it off and back on.
After some research I notice the the Vizio FAQ mentions a similar issue for which the solution is to unplug the unit for 3min.
After calling Vizio, they suggested that under the menu option Setup, Picture, Advanced Video Features, I should try turning off Advanced Adaptive Luma and Backlight Control.
Aug 14, 2009 | Vizio VOJ370F 37 in. LCD TV
My HP turns on but the monitor says there's no video input and the keyboard and mouse aren't working. It worked fine yesterday but when I went to turn it off for the night the screensaver was frozen and...
Ok that sounds like to me that your computer either froze or crashed. Could you please tell me how long you have had the computer? Also what you should do is every desktop comes with a built in video card but what you need to do is go out and buy a new video card for your computer and see if that solves the issue. Also another thing is that if getting and installing a video card doesn't work then you may just need a new CPU board and those aren't expensive at all.
Apr 07, 2009 | HP Media Center m7060n PC Desktop
Installation of wii
I had the same problem on a 32" rca crt. It worked fine, power was cut during electrical work and when it came back, "unusable signal." I went into the menu, then channel, then video input source. had to change it to the correct input "s-video in my case" Then it worked. GOOD LUCK!
Feb 14, 2009 | Nintendo Wii Console
Can't exit the menu screen!
you need to do a firmware up date on the tv had the same trouble
Jan 03, 2009 | Philips 26MF231D 26 in. LCD Television
Solution
if it affects all inputs including the MENU or OSD on tv .There is a good possiblity your set need a whole new LCD panel .The panel comes withe digital board that when going bad will display weird images on screen.It is not available on its own .It only comes with new LCD panel.If it affects only certain inputs then you have a (B) board bad on tv .So tv might need service in the furture..
Nov 26, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
