Question about Haier Heating & Cooling
I have a window unit (ESA 3109-L) that I purchased this summer. I came home from a long weekend away to find water all over the window sill, drywall, and floor. It's coming from the air conditioner. Any suggestions?
    Genius:
  • 1,400 Answers
First.The unit needs to be tilted back more so the water drains out of it to the lower back of the unit.
Next,make sure the drain hose or hole is not clogged up.
Last,if this never happend before be sure you didnt have any bad wind and rain while you were gone,somtimes a hard driving storm with wind drivin rain can find its way in around the a/c .
Posted on Aug 25, 2010
Condensation window air conditioner unit
change the condensed water pipe
Sep 10, 2013 | Heating & Cooling
Now it is summer, and we have a horrible smell coming out of jacuzzi drainage, what should we use to get rit of the smell
hiya:) all tubs,sinks,etc are plumbed w/a P-trap which holds water and prevents sewer gasses from venting into your home. if the unit has not been used in a while the water may have evaporated, allowing the sewer gas to pass freely into your home. this is not only unpleasant it is potentially dangerous and/or unhealthy. IF the unit has not been in use for some time then just run the water for a min and the smell should go away. If this is not the problem just text me back and we'll go from there:)
Jul 27, 2011 | Whirlpool Aquatic Infinity Ii 2 Tub...
We just purchased a home with a beckett heater. we cant stop it from heating the house, it is 80 degrees in here and the heater is off! its burning up oil like crazy but we are only in need of the hot...
Terry, most units like yours had a Winter and Summer setting. It should be located on the furnace itself. In the Summer mode, only the water is heated for domestic use and the furnace side of the system is shut down.
Apr 05, 2011 | Heating & Cooling
Drainage occurs near the front of the unit, resulting in pools of water leaking onto my window sill. Unit is installed properly, there is no drain hole to direct water away from the insides of the walls...
The A/C unit should be tilted slightly to the rear and this will allow the water to leak to the outside of the window, you may have to drill a small hole in the case to drain if there is no pre-existing hole.
Aug 15, 2010 | Frigidaire FAC126P1 wall/window Air...
Hi: I have a Maytag refigerator and the Ice cube maker stopped working, now I would like to tell you that this is a summer home and we only use it on weekends, We have been shutting off the water to the...
the problem of your refrigerator is you unexpetedly turn it off thas why the protective overload of the ice maker colaps you will find it at the back of your frige with the electronic circuit bord.. you see all your overload protection in that board in short term FUSE...
Aug 09, 2010 | Maytag Refrigerators
I have an extension in my house where the bricks are flaking and crumbling. its not rising damp as the bricks are very dry. the worst affected areas are just under the window sills. Please help Vladimir
Check all round the window and ensure a good seal with the brick and sill [use silicon sealant at the joint between the window frame and the brick & sill and brick] and that the sill has a drip bar [ridge or channel under the sill running sideways at the furthest away from the wall] If not put one on the underside. Almost anything will do [sounds silly but an elastic band will do temporary or even a line of the silicon] so long as it collects the drips from the sill. also ensure that the sill slopes downward & away from the wall
How old is the extension ?? I ask because if it is 50+ yrs you may have lime mortar which lets the bricks breath and if this has been re-pointed later with non- lime mortar [i.e. portland cement mortar] any water which gets in above will not escape out through the lime mortar below.
Secondly, if this is a north or east facing wall getting little sun and if the bricks were originally not good, frost & freezing will cause the flaking.
Bricks - has the wall been built with facings or commons. commons will spoil [flaking] sooner.
Do your bricks have a frog. That is a hollow in the middle [& looks a bit like a cake which has sunk in the middle] The frog should be facing down otherwise water will collect You can only check this by taking a brick out [applies mainly to modern bricks ]
Oct 22, 2009 | General Hand Tools
Sill supports for window air conditioner...no sills
ok do not worry...every unit comes with outside supports that allow you to tilt the uinit to the outside a little so the water discharge can leake outside and not inside your house...one support go in eachside under th eunit one side connect to the wall and the other side connect to the bottom of the unit...
the whole is need on the side you are going to let the water out...the unis discharge lots of water and need a way out and the hole is for that make suer it is on the back close to the corner and far away from any moving part.(I usually find a place under the fan that is if they do not have one pre-driled
Sep 07, 2009 | Heating & Cooling
My lgl1006r is leaking from the back of ac is that normal????
This is completely normal for a window a/c unit. The purpose of the leaking is to leach the humidity from you home in the summer. When the house is hotter the air is inherently more humid. As warm air is passed over the condensors in the unit it turns into water and should drip out of the back of any air conditioner unit. It essentially turns into distilled water. Not a problem and don't worry! Enjoy the air!
Aug 02, 2009 | LG L1006R Wall/Window Air Conditioner
Leaking air conditioner
yes let it tilt out the wondow so it can drain outside and not inside it only needs a couple of inces to raise the face of the air cond up so it can drain outside
Aug 19, 2008 | Heating & Cooling
Installing room airconditioner
what i did was buy a 2x6 cut them all into about 18 inches in length screwed one piece onto the window sill and the other 3 i screwed into that piece going out the window so the a/c unit sits on the wood pieces and clears the window sill that way i dont have to worry about the a/c unit weight on the window it was all on the wood pieces sticking out
Apr 28, 2008 | Heating & Cooling
Heating & Cooling Logo
100 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
