Question about Traxxas Rc Revo Nitro Monster Truck
When i start my truck the motor starts to REV very high and wont go i can see the gear spin at the bottom but think maybe something is not catching up top. last time i drove it was fine it did REV up before but think it was from low charge
  • 748 Answers
Hi
you have two different problems. The engine is reving high because fuel into the engine is being starved i.e. the fast idle is set too high. This can eventually lead to a ruined engine. Traxxas engines are designed to run very rich with a heavy amount of oil to keep them cool. Retune your engine. Secondly your clutch shoes have probably glazed over or are simply worn out. Replace these. There's alsways a possibility that you've broken a gear in the transmission but the clutch shoes are much easier to replace and probably should be at regular intervals. Your manual will explain how to change them and how to retune. Good luck
Posted on Aug 26, 2010
I have 20hp mercury in neutral can rev high but when in gear full throttle it's like trolling speed
Take the cover off and check that the throttle linkages are all secured to the clips. May also be bad fuel, or moisture in the fuel. I use stabiliser over the winter. With a motor stored that long, it would be prudent to get it professionally serviced.
Jan 26, 2017 | Mercury Cars & Trucks
97 roadking, not going into gear, starter just spinning while bike is in neutral, in gear bike just free-wheeling push the starter and bike lurches forward but then starter just spins
Hi Rod, sounds like your starter drive is going south. I'm sorry you can't find the first and very best tool your Road King ever needed, but don't despair for a mere $6.50 you can download another one at the website below:
Harley Davidson Manuals Mark Workshop
Good luck and enjoy the video.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 26, 2014 | Harley Davidson FLHR-FLHRI Road king...
Stealth flyer ii bottom propellor wont rotate. any help on how to fix
Ya, I've got that problem too. I note that the bottom rotor spins without turning the gear inside the copter (I can hear the gear when I turn the top rotor. So I'm thinking that maybe the rotors plastic sleeve was glued to the shaft and that came loose. But I'm a little hesitant to put glue in there until I'm sure!
Dec 29, 2010 | Toys
Motor wont rev up when starting cold with choke on trys to run on idle but will not rev up
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
Dec 26, 2010 | Honda 8 HP Engine
2004 Linclon LS went to start it wont start makes a winding noise sounds likes its not catching
Sounds like the gear on the starter is not sliding forward on the shaft to engage the ring gear so what you are hearing is the starter motor spinning free. So absent any other clue I would suspect the starter needs to be replaced.
Nov 29, 2010 | 2004 Lincoln LS
Got really cold now it wont start it just spins like it wants to but wont catch.
Your starter has a solenoid that throws the gear on the starter motor into the flywheel to turn the motor over.The small gear is either sticking on the starter shaft or the solenoid is not pushing the gear into the flywheel . You will have to take the starter motor off and bench test it to see what the problem is. It is typically cheaper to buy a rebuilt starter at the local auto store and just replace the starter assembly if it has high miles on it. Be sure to bench test your new starter to make sure it is working correctly before installation.
Nov 28, 2010 | 1997 Plymouth Voyager
Car dies after driving through some water (it has been a week)
I believe you have a motor from GM where your distributer is on the bottom and therefore your wires are wet as well as the distrib cap
Jul 31, 2010 | 1997 Pontiac Grand Prix
Smoke from motor
something has got you motor in a bind. if it starts to smoke right after your spin cycle starts, it could be a bearing in the motor trying to seize up or it's a bearing in the bottom of you tub. if it your motor it will need replacing as quick as possible it could catch on fire. my opinion is to take it to a repair shop.
May 02, 2009 | Washing Machines
Ford F-350 6.0 Turbo Diesel - Severe Hesitation at Take Off
sometimes when the motors under enought pressure it will black smoke..so mabe the transmission is hanging up or something in first gear,,,i can rev my truck up all day and it wont black smoke when these a sever load o it and i hammer down it putts a bind on the motor and fuel is steadly being pump into the motor causing unburn fuel witch is black smoke..so maybe you want to go check the transmission or the fuel PUMP not the filters
Apr 22, 2009 | 1997 Ford F350 Crew Cab
96 dodge neon wont start
i dont know if this will help but i needed new spark plugs and wires and something called a leak pump which had something to do with the fuel line so have it check for one of those problems, that just may be it. i hope that this helps you.
Mar 22, 2009 | 1996 Dodge Neon
Traxxas Rc Revo Nitro Monster Truck Logo
287 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
