Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Lawn mower only runs when hold idler arm - Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
This is the way is was designed to work
Posted on Aug 24, 2010
How to reinsta l idler pulley arm
Commercial Mower Maintenance-Replacing Idler Pulley ...
? 3:44
www.youtube.com/watch?v=io2aCjM0o8Y
Sep 30, 2011 - Uploaded by askanthonynow
After new bearings were placed into an idler pulley, it is being installed on the deck of the mower. This is the .
How to Replace the Deck Idler Pulley on a Troy-Bilt Pony ...? 8:04www.youtube.com/watch?v=HY9AuNe5DWAAug 13, 2013 - Uploaded by eReplacementParts.comThis tutorial will show you how to remove and install the idler(4.25") pulley on a Troy-Bilt Pony lawn tractor/riding mower. Helpful items include ...How to Fix the Idler Spring on a Zero-Turn Mower ' Home ...
Nov 01, 2015 | Yard Machines Garden
'how to replace idler spring on sears 917.275640'
unhook idler arm istall spring on deck and idler then reinstall idler arm this will take two people to do one to hold in position one to bolt in and tighten sometimes if its a week spring one person can do it
Sep 01, 2014 | Garden
Yardman riding mower won't pull
Hi, there is an idler pulley that runs on the rear belt that you replaced, make sure the idler arm rotates freely on its pivot bolt and make sure the spring that holds the idler against the belt is not weak. Regards Phil.
Jul 05, 2012 | Garden
I have a Craftsman mower, model 917.273810, and when you engage the blades, the brake pads that are used to stop the blades from turning when you disengage the blades...won't release and it trys to...
Sounds like you have a broken spring #148 on diagram, part #169022 that holds the idler arm back. Go to www.searspartsdirect.com and enter the model # of your mower and click on the mower deck to print drawing out, take your deck off the mower and see if all the springs are ok. If the pads are closed on the pulleys and the pads release when you turn the idler arm, the deck is ok. The problem will be a bad or disconnected safety switch that cuts the motor off if you try to ingage the mower. If the switch is disconnected under the seat it will kill the engine when the mower is engaged. I had this problem on my mower, just plug the wiring into this switch or replace it if it is bad.
Aug 16, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need to see a belt routing diagram for a Scotts Mower
This is for a Scotts 1642. Picture yourself sitting on the mower looking down at the deck. Starting at the tractor pulley, the belt runs from the right side of this pulley to the left side of the tension arm pulley, around this pulley to the left side of the right hand side mower blade pulley, around this pulley, across the deck to the smaller left hand side idler pulley, then up to the left hand side mower blade pulley, around this pulley to the second (larger) idler pulley, around this pulley and back to the left side of the tractor pulley. If you make a small sketch of the deck pulley arrangement it will be easier. Keep in mind some of the pulleys are for the "V" side of the belt and some (The tension arm pulley & larger idler pulley) are for the flat side of the belt. Be sure the belt is not twisted and lays in a continuous circle with the "V" side of the belt on the inside before you start.
from http://www.ssbtractor.com/wwwboard/view_all.cgi?bd=lawn&msg=135
Please vote !!
May 12, 2010 | Garden
Idler arm 1045 cub cadet
Check for alignment of all the pulleys--esp the idler arm. Probably enough out of alignment to "work" the belt off----possibly bent?
Feb 27, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Where does the manual clutch cable mower deck spring connect to on a Craftsman YS4500?
It should connect on top of the idler pulley on the idler arm. The bolt is extended and the spring hooks over it with a 'hairpin' or cotter key through the hole in the end to hold it on.
Oct 09, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I can't disingage the lever to cut grass on my craftsman riding lawn mover. Now because of this I can't start the mover.
the lever moves an arm on the deck connected to a pivoting plate holding the idler pulley. when you push up the lever, it pulls the pivot [and idler pulley] back and puts tension on the belt. if this pivot gets rusted, it sticks and won't release tension on the belt. find the pivot point and lubricate it thoroughly with oil, wd-40, or liquid wrench, then work it back and forth by hand until it is freed up
Aug 02, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 20hp tractor starts with mower engaged.
OK. You have one of two problems, or maybe a combination of the two.lol. Either the clutch cable that runs from the lever to the deck is frozen, or most likely, the pivot point on the idler arm on the deck is rusted up and is not disengaging. Spray some penatrating oil at the base of the bracket the idler pulley is mounted on (pivot point) while working it back an forth until is loosens up. There is also a spring that is hooked to the idler arm and to a slot in the middle toward the front of the deck to pull the arm forward when the blades are disengaged. Make sure that is in place also.
Jun 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Can't get stick to move down to disengage, push with all my power
With the engine off, reach under your deck and pull on the belt. This will force the idler arm back into disengaged position so you can start it. You can probably free the mechanism up with penatrating oil by spraying the pivot point on the idler arm ( the bracket the idler is mounted to that moves back and forth) while alternatly engaging the lever and pulling the belt till it frees up and returns by itself.
May 25, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
52 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
