Question about Frigidaire FRT18G5A Top Freezer Refrigerator
How do I access freezer drain to unclog, clean out?
  • 4,793 Answers
Its easier to blow/syringe it backwards from the drip tray.use neat clorine bleach.
Posted on Aug 25, 2010
  • Frigidaire Master
  • 1,606 Answers
You have 4 screws holding the control panel up , in the refrig section . Remove those screws and the panel drops down . Pull foreward and the hole in the back wall is the drain hole . Use a piece of small hose , insert into the hole , and blow thru to clear . ALSO , use caulk around and thru the control panel before reinstalling it , as the styrofoam could have shrunken , allowing defrost water to drip into the refrig section .
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have an amana abb2522feb bottom freezer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
heatman101
  • 43501 Answers
SOURCE: Hello, I think my freezer drain is clogged in my
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 09, 2010
oldTech2332
  • 2341 Answers
SOURCE: I need to clear the
The way to check that everything is clear pour some water over the evaperator coil in the freezer and see that the water drains very quickly. Also you could use a can of compressed air that you would use to clean the keyboadr and what not on your computer and blow it in drain and clear anything remaining
Gene
Posted on Aug 03, 2011
Show a picture of the drain tube so I can access it with the back of the refrigerator off
There should be a tube, that leads to a defrost pan, under the box. Follow it up to the freezer. If the freezer is still freezing, you may never get it unclogged.
Sep 07, 2014 | Refrigerators
Unclog a/c drain on mitsubishi ductless mr. slim
you should have a drain on the outside of the house take a shop vac and suck this drain line out, Make sure your filter is clean.
Jul 15, 2014 | Mitsubishi MS-A12WA & MU-A12WA Mr. Slim...
Need help to unclog a drain on a GE Profile Bottom Freezer Refrigerator Model PFSS6PKW/PFSF6PKW. Specifically, where does the drain end? Behind the freezer & how to access it? Also found eroding t
You should be able to see where the drain tube comes out over the drain pan. Get some thin wire and run it down the tube and when it comes out in the drain pain, tie something onto it like a small piece of cloth and pull it back up through the drain tube to swab it out. The tape is no big issue, if you want to do something about the rust, there is a product that autoparts stores sell that turns rust into a hard, rigid metal. Or you can use a blow drier to make sure it is dried out and then spray rubber under coating on it.
Nov 18, 2013 | GE Refrigerators
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
I need to clear the drain line on my Amana ARB1917 bottom freezer refrigerator. I've accessed the short tube that is supposed to move the water from the fridge/freezer to the drain pan ... it's...
Gene
Aug 03, 2011 | Refrigerators
Where is the drain llocated and how do i unclog it?
The drain is always under the freezer coils. On a lot of side-by-side models you can see the drain without taking anything apart just look at the bottom back of the freezers. On some side-by-sides and all top freezers you will have to remvoe the cover off the freezer coils to access the drain.
Once you access the drain remove all ice that is on top of the drain. Then use a turkey baser to force hot water down the drain untill water flows freely. The mix baking soda with water and pour it down the drain. Check out this page http://www.appliance-repair-it.com/refrigerator-leaking.html
Oct 07, 2010 | Refrigerators
How do I access the freezer drain to unclog or clean it out?
heatman101
Aug 24, 2010 | Electrolux Refrigerators
The defrost drainage appears to be clogged in my freezer. I have removed all of the ice and can see water pooling at the drainage area. I have tried to unclog the drain, but it is hard to access this area....
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the freezer so you can get at the drain. then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the refrigerator side as well.
Good Luck,
Gilsh
Nov 28, 2009 | Frigidaire FRS3R5EMB Side by Side...
Upright freezer
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 14, 2008 | Freezers
Leaking frig.
  • take out the back wall of the freezer and physically clean out the line. you may need to run a coat hanger or something down the drain to unclog it. also pour some hot water down the drain after you think you have it unclogged.
  • the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Jul 06, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Frigidaire FRT18G5A Top Freezer Refrigerator Logo
199 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
