Question about Mantis 2-Cycle Tiller
Starting instructions on off switch only labeled O and -
  • 183 Answers
O and I are the international symbols for off and on. The O is the off position and the I is the on position. Put the switch in the I position. Make sure there is properly mixed fuel in the tank. Your Mantis probably uses fuel mixed 1 part 2cycle oil to 50 parts gasoline. Push the primer bulb a few times until you see fuel in the bulb. Position the choke lever to full choke, open the throttle completely and use short, quick pulls on the rope until the engine sputters. Reposition to choke to half and pull the rope again. The engine should start at this time. Let the engine run for a few seconds, then push the choke lever to off. Go to work in the garden.
Posted on Aug 25, 2010
Why are my labels coming out grainy while printing?
check your ink status.You may be needing more ink. Follow the instructions when putting new ink in and do a test page.That might help
Apr 03, 2016 | Kodak Office Equipment & Supplies
How to start water heater
For tank-type gas water heater, lighting instructions are usually shown on label on front of unit.
Look at label on side of unit for Brand, model and type.
If you have tank or tankless.
If this is new installation or old installation that stopped working.
About how old unit is.
If this is gas or electric.
Then add a comment for possible help.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 10, 2012 | Water Heaters
Label describing switch positions missing
when you remove the cover of the heat pump stat there used to be operating instructions on the inside of the cover.
Apr 15, 2010 | Honeywell Heating & Cooling
I need to replace a shower cord but it has no instructions please advise on what wire goes where
Three wires in 3 out each set of 3 in a cable
Earth green/yellow attach to brass earth terminal on switch back - both cables and make sure that the copper wires have a plastic sheathing on them
input cable -
red or brown to live labeled 'L' on the terminal of the switch labeled 'IN' or 'MAINS'
black to the terminal labeled 'N' on the same part of the switch
Output to shower-
as above but to the part of the switch labeled 'LOAD'
The neon will be prewired to the LOAD side - take care not to disturb
To help to remember which cable is which, place a piece of tape on one cable to identify either MAINS or LOAD. Or red marker pen to the MAINS cable
Mar 23, 2010 | Home
Can I install a motion sensor switch on a 3-way switch?
In many cases, yes. When shopping for an occupancy sensing switch, read the label to make sure that it's compatible with 3-way switching, and then follow the installation instructions.
Feb 06, 2010 | Hubbell HBL1221I Industrial Series Switch
Easy coder
Switch off the power. Hold down the Feed button while you switch the power back on.
After the Configuration label prints, turn the power off and on again, then try printing again.
Aug 21, 2008 | Intermec EasyCoder PC4 Label Printer
Empty light
The label sensor on the 3400 is in the hinged area where a metal plate swings down to make loading labels easier. The sensor can't be adjusted left or right like some other Intermec models, so it's critical that the labels be snug to the left side (as viewed from the front) so the sensor can read the leading and trailing edges of the labels.
There is a small "Guide" in the slot of the plate that should keep the labels in position. Use the thumbscrew beneath the plate to adjust the guide so that the labels are snug but you can still pull the labels without much effort (with the head open). This almost always fixes the problem. If the guide and tumbscrew are missing, look in the bottom of the printer for the pieces, including the washer.
Close the head, hit the Feed button a few times, and labels should feed consistantly (the feeds should probably move the label to the start of the printhead and then to the tear bar).
If the labels still don't feed, be aware that the same light is used to show that the ribbon is out. If you use direct thermal printing (without a ribbon), check the bottom switch on the back is set toward "DT" and then turn the printer off and on to read the switches.
Oct 29, 2007 | Intermec EasyCoder 3400 Thermal Label...
Mantis 2-Cycle Tiller Logo
540 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
