Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Filter will not clear the maintenenc cycle. - Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
    President:
  • 180 Answers
YOUR MACHINE COMPRESSOR IS FAULTY. PLEASE CHANGE THE COMPRESSOR THAT'S ALL.
Posted on Aug 25, 2010
What is the lifetime of fuel pump on 1500 dodge hemi 5.7l? can loss of oil cause failure?
well it all depends normal life for a fuel pump should be at least 60k but they go out alot on all makes and models, due to dirty fuel filters and sediment in the tank or dirty gas, so really it depends on how the fuel delivery system is maintenenced, but on thing for sure is that oil loss couldnt not have any effect on the fuel pump or any part of the fuel system
Aug 31, 2011 | 2004 Dodge Ram 1500
There is still water on the dishes and in the dishwasher after the heated drying cycle. Not a lot but enough to wet the kitchen floor. What can we do?
check the kitchen drain is clear - looks like the drain cycle is not working efficiently.
Also make sure the filters at the base of dishwasher are clear.
Try a short cycle (like rinse only) and see if water drains at the end. If problem is occuring only during the normal wash cycle, then drying fan may be the problem.
Jan 08, 2011 | Whirlpool DU1055XTS Built-in Dishwasher
All the cycles are working but the washing machine will not rinse the excess water left. I have tried to take out the filter but this is stuck and will not move so the water sits in the washing machine. ...
Do not run the machine until you have cleared the filter or you will burn the pump out. You need to keep working the filter until you are able to get it opened and cleared.
Dec 31, 2010 | Baumatic BTWM4 Front Load Washer
When driving my toyota estima blue smoke from exhaust for a while why
Depending on mileage and how well maintenenced the vehicle is, the valve seals within the cylinder heads can get worn out. When they wear out you can get smoke from your initial start up. If it is a persistant smoke then most likely it's the piston rings that are worn out.
Jan 10, 2010 | 1993 Toyota Previa
Whirlpool washer: Very slow fill cycle on the
I had a similar problem - unscrew the water hose feed lines from the back of the machine and clear out any sedimentation build up from the filters. You can use a turkey baster to siphon off. If filters are clear you may have to replace watervalve. Look at vitual repairman,com as to how to remove the back. Replacement cost about $26.
Mar 27, 2009 | Washing Machines
Hotpoint aquarius ultima 1000, when wash cycle is comple the rinse cycle wont start and displays message check outlet pipe which i have done but it seems to be clear as i can syphon water from the machine...
It sounds as though the pump is not draining the water out.
If you have checked outlet pipe and it is clear, then you need to check the filter, if there is no filter at front of m/c, then remove the rear panel, and unfasten the large black hose that goes to bottom of drum, remove filter and clean, check pump at same time.
Watch out for water from the drum.
Refit filter and hose and test.
Plz rate my suggested solution, and feel free to leave a comment.
Thankyou.
Jan 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
I can not access the link you gave me to answer my question. The screen comes up but it is blank.
The URL you need for instruction manuals and software is:
http://na.blackberry.com/eng/devices/device-detail.jsp?navId=H0,C65,P726#tab_tab_getting_started
If you could not connect, perhaps they were down for maintenenc.
Please try again.
Dec 06, 2008 | RIM BlackBerry 7290
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
48 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
