Question about Hughes Televison & Video
I have a Hughes HTL-HD receiver that appears to have no power. The main fuse next to the 120vac cord is good & I cant find schematics or even any place to take/send it for repair. Any suggestions?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 61 Answers
Check first the main power supply which is AC line get the voltage reading.if it is right check the plug of your Hughes HTL-HD receiver so if the problem is still going on, check the power supply section.
Posted on Aug 25, 2010
I HAVE A JENNAIR JS42CSDBDA FRIDGE THAT WENT DEAD NO POWER,NO LIGHTS CHECKED OUTLET AND FOUND POWER GOING TO FRIDGE BUT NOTHING. IT ACTS AS IF IT'S NOT EVEN PLUGGED IN.
No one turned off your power switch up above the refrigerator, I trust. So, either your power supply or your main PCB is blown. Check the fuse on the main PCB (up on top of your refrigerator in the compressor area). The fuse will be right next to that round, black piezo electric speaker on the main PCB board as shown here:
If that's not it, then check to see if your power supply board is supplying power by measuring the voltage on JP11 of the Main PCB. You should see 26 vdc between pin 3 (GND) and pin 1. And, you should see 12 vdc between pin 3 (GND) and pin 2.
If you don't get those voltages, then you might have a bad Power Supply Board. It looks like this:
Also of note, your 120vac going into the Main PCB board comes in on JP8, pin 1 (WHT) and pin 5 (RED).
I don't know if you will be able to see the larger image of the schematic, or if Fixya will just give you a thumbnail, but I'll try to post it here, anyway:
Well, good luck and let me know if you need any more assistance.
Oct 20, 2014 | Jenn-Air Refrigerators
1997 Harley Ultra Classic 30 amp main breaker pops while riding. Also blows 10 radio power fuse
Hi Anonymous, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and start tracking the wire from the power side of the switch, circuit breaker or the blown fuse receiver, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Jul 19, 2012 | Harley Davidson FLHTCUI Electra Glide...
No power up, not power cord, properly seated good outlet. Hit power button last night to power off, wont come on today.
You will have to open the unit up and check 3 Components, The Main Fuse(located next to the 120VAC input, The Bridge Rectifier, and of course the Capacitors. If you still have a problem; Please post I.D. #'s of the power inverter online including revision data.
Jan 30, 2011 | Dell E207WFP LCD Monitor
My Pioneer VSX-517 receiver will not power up. Have checked power cord & fuse.
good start. the next is to chech standby voltage 5 volt, that goes to the microprocessor which will enable you to turn-on the main relay(12 volt)that powers up the whole unit. so if you cannot hear a click when you push the power button the the standby transformer capacitor and the 5 volt needs to verified. if this is good the relay - 12 volt and if this is also good the micro is bad. oops-hope it doesnt come to that. the micro is located on the circuit board mounted on the faceplat-a large many pins IC.
Feb 26, 2010 | Audio Players & Recorders
I have a "peavey ultra 410" guitar amplifier. it has been sitting in the garage for several years, and there is no power when plugged in. The amplifier is all tube (preamp and amp). My question is this; if...
Even though I don't have a schematic, if you have a VOM, (Volt-Ohm, Milli-Ammeter) we can start. Just because tubes are old doesn't mean they are used up. If a tube doesn't light up that would be a bad one, but they are in parallel off a winding of the power transformer. 1.) Check the on/off switch with the ohmmeter and the line cord for conductivity. 2.) Check the primary winding of the transformer for a low ohms reading. (less than ten ohms). 3.) Some where between the power switch and the pwr. trans. should be a fuse. After these three you should be able to put 120vac. to the unit and bring it back on. Get back with us, Dale
Aug 04, 2009 | Audio Players & Recorders
Wont turn on and shows no lights acts like not plugged in
Hello tkeymer, I’m an owner like you and will try to help. Have you had any recent electrical storm activity? Is the 120V AC source power supplying the machine on a surge protector? Good troubleshooting steps in verifying 120VAC at the service outlet, was that done with a Digital Volt Meter? If so do you feel OK to troubleshoot 120VAC power? The service manual/schematic doesn’t document the EMI filter (see page 31 of the SM) very well. I believe 120VAC power will pass thru that before being distributed in the machine. I would check 120VAC thru the EMI filter. If it is good there then we would have to get into deeper troubleshooting and verify power to the control board. There are no internal fuses that I’m aware of in the machine. Power is applied to the machine thru the main system relay K6 per the FAV6800AW schematic The FAV6800AW schematic is located in the console of the machine. If you feel you are not qualified to troubleshoot 120VAC power in the machine I would call in a qualified repair service that is familiar with the FAV6800AW. This could be a dead Control Board issue but without a known good Control Board to swap out all we can do is verify power to the control board. Let me know how far you want to go in troubleshooting. Service Manual and Sears Parts Direct for reference.
Jul 10, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Program Code
DIRECTV Model D-10 00001, 00002
Hughes Network Systems (most models) 00749
Hughes Network Systems models GAEB0, GAEB0A, GCEB0, GCEB0A,
HBH-SA, and HAH-SA 01749
GE models GRD33G2A and GRD33G3A, GRD122GW 00566
Hitachi model HDS210R 00819
Mitsubishi HD models SRHD400 and SRHD500 00749
Panasonic models TZ-DBS01 and TZ-DRD100 00247
Panasonic models TUIRD10 and TUIRD20 00701
Philips models DSX5150R,DSX525R/I, DSX5350R, DSX5353R,
DSX5353X, and DSX5375R 01076
Philips models DSX5500 and DSX5400 00099
Proscan models PRD8630A and PRD8650B 00566
RCA models DRD102RW, DRD203RW, DRD301RA, DRD302RA,
DRD303RA, DRD403RA, DRD703RA, DRD502RB, DRD 503RB,
DRD505RB, DRD515RB, DRD523RB, and DRD705RB 00566
RCA models DRD202RD, DRD221RD, DRD222RD, DRD223RD
DRD225RD, DRD420RE, DRD440RE, DRD460RE, DRD480RE,
DRD430RG, DRD431RG, DRD450RG, DRD451RG, DRD485RG,
DRD486RG, DRD430RGA, DRD450RGA, DRD485RGA, DRD435RH,
DRD455RH, and DRD486RH 00392
Samsung model SIR-S60W 01109
Samsung models SIR-S70, SIR-S75, SIR-S300W, and SIR-S310W 01108
Sony models (All models except TiVo and Ultimate TV) 01639
Toshiba model TSR101DSS 00790
Uniden model UDS100 00724
Setup Codes for DIRECTV HD Receivers
DIRECTV Model H-10 00001, 00002
Hitachi model 61HDX98B 00819
HNS models HIRD-E8, HTL-HD 01750
LG model LSS-3200A, HTL-HD 01750
Mitsubishi model SR-HD5 01749, 00749
Philips model DSHD800R 01749
Proscan model PSHD105 00392
RCA models DTC-100, DTC-210 00392
Samsung model SIR-TS160 01276
Samsung models SIR-TS360 01609
Sony models SAT-HD100, 200,300 01639
Toshiba models DST-3000, DST-3100, DW65X91 01749, 01285
Zenith models DTV1080, HD-SAT520 01856
Setup Codes for DIRECTV DVRs
HNS models SD-DVR80, SD-DV40, SD-DVR120,
HDVR2, GXCEBOT, GXCEBOTD 01442
Philips models DSR704, DSR708, DSR6000,
DSR600R, DRS700/17 01142, 01442
RCA models DWD490RE, DWD496RG 01392
RCA models DVR39, 40, 80, 120 01442
Sony model SAT-T60 00639
Sony model SAT-W60 01640
Samsung models SIR-S4040R, SIR-S4080R, SIR-S4120R 01442
10
PROGRAMMING
Jan 26, 2008 | Directv RC23 Remote Control
Televison & Video Logo
116 people viewed this question
Top Hughes Televison & Video Experts
Jim London
Jim London
Edward Talavera
Edward Talavera
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
