Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP officejet 6110 all in one scanning
Having used te printer for a long time and the fax I tried to scan.
Following a failed attempt to initialize the scanning process a fault message appears saying
scanner failure
turn pawer off and on again
When completing this it restarts the same problem without correction
Te problem occurs whether or not the printer is connected to the computer
Any ideas
  • 975 Answers
LOOKS LIKE YOU HAVE A MECHANICAL PROBLEM , need to check the motor , guidance path where the bright light travels , needs to be serviced , hope this helps
Posted on May 05, 2008
When I try to scan something on my HPofficejetJ5750 all in one I get an error Cycle Power and try scannin again what does this mean?
This is covered in the following support document from HP: (start troubleshooting at the top of the page, quit when problem resolved). Failing these solutions, your OfficeJet 6110 may need service/repair.
HP Scanner Failure, Power Off/On
Jan 04, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp all in one faxing
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Apr 24, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Black page printwhen I try to copy or fax from my hp 6110 printer
The printer isn't shot, but the scan assembly is, it sounds like either the scan lamp is dead or the sensors in the scan assy. You should also be getting a scanner error. I would try the reset, powering up with either the #3 or #6 buttons pushed, and see if a reset helps.
Jun 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't find how I initiate a scan on my HP 6110 all-in-one
I suppose there was a problem in your driver installation. For most USB devices, it is recommended that the drivers be copied/installed on the pc prior to attaching it via the cable. So, if you attached the printer to the pc before copying its driver to the hard disk, you are likely not to have the right result ok. Put back the driver cd/dvd into the drive tray and uninstall. Restart your pc and then follow the step above. Good luck
Jun 02, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My hp office jet 6110 all in one will not allow my hp pavilion dv 5000 to initiate a scan from the "director". I have reinstalled the drivers that came with the printer several times and of course...
Hi greggcowley, having two HP's connected or bouncing between either you need to change the default printer before using either. Open printer and faxes. You'll see only one device has a check mark on it. So before you go to use the 6110 left click on it once, than click File & set to default printer. Same for the DV 5000. Each time you'll need to open printer & faxes & change the default printer/scanner.
Enjoy greggcowley!
Thank you for using fixya.
Merry Xmass!
Mike
Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Can't scan with HP Officejet 6110 from document holder
well u can try:
1/uninstall and install printer/scanner drivers and software.
2/ replace the usb cable.
3/make sure that there is no damage va been maen on th AIO cuz u need a warrantly in this case.
plz do rate this post.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning
Try using the scan program provided by Hp already installed in your computer.
Double click on "My PC" select the OfficeJet scanner icon and do a the right click, and then order to a scan.
Oct 27, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning problems w/officejet 6110
Remove the HP software then reinstall the software from HP's site
Sep 24, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 scanner fault
There is a sensor on the right that is probably not working or is out of place. turn off printer and open door , move printhead all the way to the left and look at the right side of the printer, is anything loose there? ( the best way to describe it is to look for a piece that is like the symbol pi )
Nov 07, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
113 people viewed this question
Ben Johnson
