Question about Cobra 29 LTD CB Radio
WHEN I PLUG IN VERY LITTLE RECEPTION WEATHER BAND COMES IN FINE. SIGNAL DOES NOT MOVE EVEN WHEN KEY MIKE, CAN'T SET SWR VERY DIM EVEN WHEN ADJUST DISPLAY
    Guru:
  • 773 Answers
1st. You cannot "set" the swr. The swr is not set on the radio. The antenna must tuned to attain an appropriate SWR reading.
2nd, If this doesn't solve your problem then you could have a worse problem. If there is a problem with the mic such as a break in one of the wires, the radio's receive will be off until you put a good mic on it. Try a different mic, and see if the receive comes back. Then check and see if your transmitting better.
As well, your meter could just be bad, as well your coax or antenna. Your receive could be poor if the antenna is not tuned to lowest SWR.
If it has been working up till recently, and you have "set" the SWR on the radio, which is not what the SWR function is for, because you don't set SWR on the radio, you could have been using the radio with the SWR super high and blown the final or other sections of the radio out.
SWR is basically signal reflection. If the antenna is not the right length, it will reflect energy back into the radio and damage it over time. The more an antenna is off from the correct length, the more reflect you will get.
The meter in the radio is used to determine how much reflect you are getting. You ideally want to have the lowest SWR possible.
To check the SWR, you set the meter switch to CAL. Key the mic. while holding the mic key down, turn the CAL knob up until the needle is at the little triangle at the top right of the meter marked by "CAL", Then while still holding the key, flip the meter switch to SWR. where ever the needle is at that point is your SWR.
You want ch 20 to have the lowest SWR. If the swr reading on channel 40 is higher then channel 1 then your antenna is too long. if it is higher on 1 then 40, its too short. Make small adjustments until 1 has almost the same reading as 40. then check ch 20 and it should be real low.
As I have said, if you haven't tuned your antenna as I have just explained, and have been using it as is, the possibility is high that you have already hurt the radio.
Although it could also have a bad meter. Use an external meter to read the SWR.
Other things to check. Make sure cable connections are tight. Make sure coax is not damaged. try another antenna.
Posted on Aug 25, 2010
Antenna warning light
if you see the red light come on before you even set the swr you already have a problem.set the radio on cal and set the needle at the cal arrow.no unkey the mic . set the meter for swr and key it again.write this # down . go to ch 40 and do the same thing, then go to 19 and repeat. now that you have your readings you need to set the antenna. Now check it again for swr on 1-40-19keep doing this until you get an even reading on those channels.
Oct 14, 2012 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
I hav a 29ltd classic cobra cb radio i had it tweaked first did not notice a diference in transmission but reception is still normal then i installed a rxf 75 amp and my reception decreased and everyone...
Receive amps on a Linear's can cause this issue---the key question is what is the dead key wattage in the radio adjusted to?
You hook an amp up--jumper cable length between amp and radio is critical---the power output of radio is critical--put 4 watts into a 75 watt amp and it will be over driven-- The proper way here is with radio and amp hooked to a big dummy load adjust the radio wattage output so the radio keys up the amp and gives maximum forward swing on a watt meter. (in some cases as little as 1 watt output from radio)
Some people call this matching the radio to the amp---The antenna system then becomes involved--further adjustment of the radio with the antenna system connected will be needed (power output) for the amp to work well.
If just a 29 LTD lowest Swr should be on channel 20.
Note: also important to check the swr with the Amp on as if power is being reflected back at radio when amp is on more needs to be done.
SD TECH
Apr 21, 2012 | Cobra 29 LTD CB Radio
I just bought a used cobra 200 gtl dx im totally clueless to cbs could u tell me where all the controls and buttons should be
  • Hi, I can help.
  • I have uploaded a pic of the Cobra 200 and labeled each knob/switch with letters to reference.
  1. A) Noise blanker - When this switch is pushed the high pitched noises are canceled leaving a more natural sounding receive. Some like it some don't.
  2. B) High Power - This button adjusts the power output of your radio. Inside the radio the pots are adjusted for a low power setting and a high power setting.
  3. C) Roger Beep - This is a beep heard by the person you are chatting with at the end of your transmission.
  4. D) The 10+ KHz - This button when pushed jumps the frequency up 10 Kilohertz to help you better navigate frequencies.
  5. E) This is where you adjust how you are going to modulate. CW is for continuous wave or Morse Code. Unless you have a key don't worry about this setting. FM is for Frequency Modulation AKA the HAM bands. AM is for Amplitude Modulation. USB and LSB are for Upper Side Band and Lower Side Band respectively.
  6. F) is the band adjustment - Each band (A, B, C, D is a set of frequencies.
  7. G) is a dimmer and the SWR calibrate. To use the dimmer push the dim button in a rapid motion. To use the SWR calibrate side press and hold the dim/calibrate button and using the SWR knob on the right side of the radio (L).
  8. H) SWR/, S/RF - If this button is in the out position then your meter will swing as usual. Push the button in to measure SWR.
  9. I) is the volume and squelch. Volume is what is adjusted to how loud you want your speaker. Squelch you adjust to take out the unnecessary white noise.
  10. J) Mic Gain and RF gain - Mic Gain is how much gain you want to your mic. RF gain is how much of the receive you want to pick up.
  11. K) Is the fine and course adjustment that you clarify your frequencies with.
  12. L) You adjust the echo and the SWR with.
  13. M) is the channel selector.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 17, 2011 | Cobra 200 GTL DX 4-Channels Base CB Radio
I don't understand how to adjust the SWR or how the built in meter works for my DX949.
Here is a basic instruction on how to adjust the SWR. When you adjust the SWR, you are not changing anything on the radio. You are actually tuning the antenna for best SWR. The lower the better. SWR stands for "Standing Wave Ratio" Or in layman's terms, SWR is energy that is reflected back into the radio. The higher your SWR reading, the more RF energy that is not leaving the antenna, and getting reflected back into the radio. This can cause damage to the transmit section of the radio. The length of the antenna is what will change this. The length of the antenna must match the length of the radio wave. The following instruction will explain how to take an SWR reading, and how to use that reading to ascertain weather the antenna is too long or too short.
Here is a quick explanation of the meter. There are 3 settings for the meter. SWR, MOD, and PWR. When you are not keying the radio the meter will show you your receive signal. How strong some ones signal is. When you have the switch on MOD and key, when you talk it shows you modulation. How much audio you are putting through the radio. When its on power, and you key the radio, it shows you your dead key wattage.
Tuning your antenna:
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to SWR
3. Key the radio. (Important. Do not talk while keying the radio.)
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Nov 16, 2010 | Galaxy Radios DX-949 40-Channels Base CB...
I just need to know how to use it for conversations and what every turn dial means.
you need to hook this up to an antenna. If you are putting it in a car, you need a mobile antenna, if in a house, you need a base antenna. The antenna needs to be tuned for best SWR or you will damage the radio.
Starting from the left of the radio.
Knob 1. Volume/ squelch. The little knob does the volume of what you hear. Big knob squelches out static noise.
knob 2. Dynamike. This is the volume of your voice transmitted. Its how loud people hear you.
Knob 3. RF gain. This is the receive sensitivity. The higher you turn this, the further you can hear. There is almost no reason for you to have this anywhere but full.
knob 4. Delta Tune. This knob should be in the center. If you encounter some one transmitting off frequency, you can move your receive up and down frequency so you can tune that person in. It does not effect your transmit frequency.
Knob 5. CAL. This is to calibrate the meter for taking an SWR reading off the antenna.
Switches starting form the left.
Switch 1. Meter switch. S/RF - will show on the meter, Your signal going out when transmitting, and the signal coming in while receiving. SWR - will show on the meter, your SWR on that channel after you have calibrated the meter. CAL - This is used to calibrate the meter in conjunction with the CAL knob.
Switch 2. ANL - Automatic noise limiter. - This gets rid of electrical interference noise from the vehicle, or other interference sources. ANL/NB - This is the same as ANL, but with NB "noise blanker" This function blanks louder noises that may make it hard to hear people. It's kind of like an automatic squelch, but not nearly as effective as the actual squelch. Also, NB will lessen your receive in that, really low signals will be blanked out.
Switch 3. CB - the radio is in CB mode. This is the normal operation mode of the radio. You can transmit and receive as normal. PA "Public Address" - If you hook a PA speaker to the PA jack in the back, you can mount the speaker on the out side of the vehicle, and talk over it (Its loud). Also, anything you receive over the radio when not holding the mic key, will come over the PA speaker. This is useful when you are not in the vehicle, and need to hear when some one comes on the radio.
Switch 4. BRT and DIM - this is the brightness of the meter light and channel display. BRT stands for bright.
Switch 5. Normal and CH 9, When the switch is in the normal position, everything is normal, but when you flip it up to CH 9 it instantly puts you one channel 9 with out having to turn the dial. CH 9 is the international emergency channel. So it lets you go to Channel 9 quick. when you put it back to normal it will put you on the channel you were on.
Meter explanation. - You have 3 horizontal lines on the meter. the top line is your SWR (only when in SWR mode on the switch. The next one down is you Signal going out. And the bottom one is your signal coming in, in DB's. ***Also noted that part of the SWR line has a CAL )calibration mark. When you have the switch in CAL, and key the mic, you turn the CAL knob up until the needle is at CAL triangle, and then put the radio on SWR and key it. where the needle falls, on the top line is your SWR. If it is in the red your antenna is not tuned, and you can damage your radio.
HERE IS HOW TO TUNE YOUR ANTENN:
2. Switch the meter switch to CAL. (CAL stand for calibrate.
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
1. Turn to CH 1
4. Turn to CH 40.
Nov 12, 2010 | Cobra 29 LTD CB Radio
I've got a Cobra 29 with WX and BT, the antenna light comes on, the swr meter barely moves and it doesn't seem to send or receive, still gets weather. May have been run with a bad antenna, got a new...
Please make sure you are tuning the antenna correctly.
1. Turn to CH 1
4. Turn to CH 40.
Now: If you have adjusted the antenna properly and you still get the antenna warning light, then the antenna warning circuit may be out of whack. Use an external SWR meter.
You may also be getting common mode current. Its when RF comes down the outside of the coax. If the swr goes up with modulation then it's common mode.
Here is how to stop common mode.
As close to the antenna as you can while still inside the vehicle, take about 6 to 8 inches of the coax, and coil it up into tight even coils and secure into shape with electrical tape.
This is an RF choke, and will stop the common mode current.
If all other radio's are fine and no ant light come one, and are all showing low swr, then turn VR6 back to disable the ant warning light. "only do this if the ant light comes on when SWR is lower then 1.5 and does not swing up with modulation showing that the ant warning light is miss aligned.
Nov 07, 2010 | Cobra 29 LTD CB Radio
I can hear people talk but they can't hear me I have a cobra29 nwst what should by settings be at
Set the switches to: 1) S/RF, 2) OFF, 3) CB, 4) HI and 5) NOR. You may change any of these to any desired position except for the CB / PA switch. This switch must remain in the CB position to transmit "over the air" - whereas the PA selection simply sends the audio to the PA jack on the rear of the radio to an external, Public Address speaker and the WX position is to select Weather Band radio reception. It is not possible to transmit on the Weather Band channels.
Choose a channel and set the squelch to MIN and Volume to a comfortable level (you can increase the Squelch slowly just until the speak shuts off if you don't want to hear static sounds). Dynamike and RF Gain both should be set to MAX. Delta tune should normally be left at the mid point. The Dimmer and SWR/CAL knobs should be set to any position you like.
Make sure you have a properly tuned 27 Mhz CB antenna connected to the back of the radio. You should review the Calibrate for SWR procedure in the manual - SWR of 1.5:1 or less are ideal, and those greater than 2:1 are bad. SWR of 2.5:1 and up may damage the radio if left unfixed. Check this list of articles of how to tune a CB antenna if you have more questions about this very important subject.
You should download & review the manual . I hope this helps
Oct 08, 2010 | Cobra GPS
Cobra 29 nw when you key the radio the swr meter doesnt move and if you move the swicth to cal you can adjust it with out keying the mike but has good recive any help would be good thanks dwayne
To check the SWR, you put the swicth on CAL and key the mike with mike gain turned down all the way,then calabrate it to the meter on the CAL scale,then swicth it to SWR before you unkey the mike, then what ever the needle falls back to, that is your SWR reading.
Apr 26, 2010 | Radio Communications
When i key up the mike the tx/rx light and the ant
your swr setting are off wack fix your swr
Oct 02, 2009 | Cobra 29 LTD CB Radio
Cobra 18 wx st cb problem
Sounds to me like your finals in the rig have blown stopping you using the CB mode, Either that or you have a loose connection on the power output inside the radio.
Mar 15, 2008 | Cobra 18 WX ST 40-Channels Base CB Radio
Cobra 29 LTD CB Radio Logo
97 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
