I have a 19" LDS K92bw monitor (2007) worked ok for a year, then I would turn it on, after a few seconds, maybe a few minutes,it would go off, turn it back on, it would go off in a few seconds, what could be the problem? I have not tried to fix it or have it fixed, I don't know if there is a local repair center near me.
  • 11,361 Answers
Three years old monitor will more likely to have bad caps by now, to have it repaired or just to look at will cost your money around $35, may be better off using that money toward new monitor.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">If you are going to DIY and have proper tools and know safety precaution then please read on:</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: <a rel='nofollow' href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Post back what you see inside so we can guide you further and it will help out other people in the future also.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a rel='nofollow' href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">Capacitors kit: <a rel='nofollow' href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a> he can make you a set of caps for you.</span>
Posted on Aug 25, 2010
My screen comes on dor a moment then goes off. What do I do?
You either have a bad inverter or a bad backlight tube.
The parts are relatively inexpensive but depending on your technical skill level it may not be worth repairing
The inverter is fairly easy to replace but the backlight will be a pain as the light tubes are extremely thin and break very easily.
Feb 04, 2015 | KDS K-92BW K92BW 19 inches WIDE SCREEN 19...
I have a SONY SDM-HS93 LCD monitor, Maybe Monitor receiverd an electric overstress, so the screen displayed but screen disappeared after few seconds. And if I turn it off & turn it on again, it turns...
Siny LCD Monitor is so expensive. <a href="http//www.wholesaleeshop.com.au/LCD-Monitor/index.php?keywords=philips">Philips LCD Monitor</a> is good!
Nov 02, 2010 | Sony SDM-HS93 19" LCD Monitor
Monitor displays the PC screen but switches off within 10 second
Unfortunatley your monitor is going out. I just had that problem. My sceen would come on, but after about 10min. it would blink off and turn black. I would have to hit the off button on the monitor, then turn it back on. It would work fine for a few minutes then black out again. I got a new/used monitor where I no longer have that problem.
I did check to make sure my hybernate was not activated, it wasn't, I had it set to never turn off.
Good luck.
Sep 02, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
I have a LCD 19"Vison Monitor that overheats.
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 31, 2009 | Hyundai ImageQuest B90A (Black, Silver)...
Westinghouse LCM-19W4
I had the same problem with my two LCM-19W4 monitors. Both failed within two months of each other. Radio Shack stocks 220uF 35V capacitors that work fine for this. You have to pay $1.49 ea though.
Nov 02, 2008 | Westinghouse LCM-19v1 Monitor
Monitor goes off after a few minutes of use. when pressing the on/off button, sometimes will turn back on. if left alone will turn back on after a few minutes. when computer is off, sometimes will turn on...
1.check power supply section any dry points
2. To replace all electrolatic capacitors in Power supply
3.Check Connectors Properly connected Or Not.
4.Replaced Microswitches in Front pannle.
Oct 06, 2008 | ViewSonic VX910 19" LCD Monitor
Dell Monitor 2007 WFP
If you are a technician you can repair it,because the problem maybe are a cracked solder joints on the feed mainboard and you need to resoldered all.Good luck
Aug 20, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
Monitor flashes image for split second then goes blank but green LED flashes as well
have you checked the capasitors?,if they,re ok then the proublem is one of the transistors it will have the letters DKQA on it ,they control the backlight power
Nov 30, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
