Question about Kenmore Dryers
Kenmore dryer, heat is not coming on during any of the modes. Model# 110.76512695
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape or with an ohm meter. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Posted on Aug 25, 2010
Kenmore dryer model 110 does not stop during automatic cycle
Make sure the small orange wire is connected to the 250 limit at the base of the heater assy. That is what powers the motor on auto cycle.
Nov 27, 2013 | Kenmore Dryers
I have a Kenmore dryer model # 96580110 and the heat won't come on when it is operating
Your Heating element may have burned out. Repair clinic has some good repair videos, and a parts department. Sears parts direct is also another source for parts.
Nov 20, 2012 | Whirlpool LEB6200 Electric Dryer
My model 400 series Kenmore gas dryer has a heating issue. At first start I can hear the gas heater ignite and heat the dryer. After the dryer has ran for a few minutes the burner shuts off and fails to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 05, 2011 | Kenmore Dryers
My Kenmore Elite Gas Dryer in Refresh mode the cloth comes out wet.
I think the refresh mode is a no heat tumble only setting... just to fluff your clothing...
if they were wet they will not dry on that setting...
heatman101
Aug 27, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
I have a Whirlpool Estate dryer Model TGDS840PQ0. During auto sense, the timer will not move. But during a "time dry" session, the timer seemse to work just fine. Any ideas?
in auto the timer will not move if there is no heat,when the heat stops the timer moves,heat comes on timer doesn't move,when it's on auto make sure power is going down to the heating system,next time send model number and if it's gas or electric,good luck
Jan 27, 2010 | Kenmore 63942 Dryer
The dryer turns on but no heat is this the heating element or something else?
Most likely it is the element. The only way to be sure is to visually inspect it.
Aug 20, 2009 | Kenmore Dryers
Dryer does not heat, drum does rotate
check the tstats on the heat can
Apr 23, 2009 | Dryers
Dryer does not create heat during a cycle.
Remove the back panel and check the glow ignitor. You may need to pull it out if you do not have a volt meter and look for a white line going across it as this would tell you it is broken. 5/16 nut drive or wrench will remove this piece and you can get one at your local appliance repair store for about 25 dollars
Feb 19, 2009 | Kenmore Dryers
Kenmore Elite HE4 Electric Dryer Model 110.85087-400
Do you have a volt-ohm meter to check the heating element and thermal fuse??? I take it the dryer comes on and tumbles but doesnt heat up???
Jan 19, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
