Question about LG LFC23760ST Side by Side Bottom Freezer French Door Refrigerator
Loud bang - blows out the safety fuse every time I plug it in
  • LG Master
  • 43,501 Answers
You have a shorted wire.... you will know where it is because it will have a black burnt spot there...
Fix that and you will be okay...
heatman101
Posted on Aug 28, 2010
I just had a new COZY L.P. GAS CDV336C installed... Every few minutes it makes a loud bang noise...It then makes pinging noises that gradually fade out...This happens 2-4 times every hour. The bang is loud...
Hi Loretta:
I'd contact the installer. This sounds as if there may be a slow leak. When the gas concentration is high enough it will ignite which would be the bang that you hear. The popping sound could be the flame at the leak source point re-igniting for a few times.
DEFINITELY CONTACT YOUR INSTALLER OR GAS INSPECTOR. THIS IS A SAFETY HAZARD.
Mar 11, 2015 | Dryers
Chamberlain half horse power garage door.Wall switch all of a sudden does nothing. made loud bang last time going up.Put latch back in above safety cord. Car remote runs motor, but doesnt raise /lower...
Sounds like your drive gear has stripped. Remove the cover from the motor unit and check the gear. It is white nylon and it will be obvious if it is bad. Sounds like a good time to take a good look at your door springs. That loud bang may have been one of the breaking.
Mar 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
So we took our 2003 Chevy S-10 truck into a local shop to get new seals as we had transmission fluid leaking. The truck was working properly when we took it in. When we went to pick it up they told us that...
a transmission that has wear tends to leak and a fluid change may not help instead make matters worst and the loud sound is bad news yes the transmission build pressure and blew it it's not common to blow fusses that unless is the fuse for the transmission or they disturbed any wire harness.
Mar 26, 2011 | 2003 Chevrolet S-10
Microwave combination oven failureHME9750GB/03 FD8106 (/555350)
APPLIANCE HAS INTERNAL 8 AMP SAFETY FUSE IF THIS HAS BLOWN IT WILL NEED MAJOR REPAIRS AND POSSIBLY COSTLY THIS FUSE ONLY BLOWS IF FAULTS EXIST WITH HIGH VOLTAGE SIDE OF APPLIANCE SO NO NOVICE SHOULD ATTEMPT A REPAIR.
Jan 18, 2010 | Bosch HME9760 Microwave Oven
Miele T358C Dryer Blew up!
it could be a shorted heating element a shorted to the case, motor start capacitor, or a defective motor ,f i would inspect the first two items closely
Sep 20, 2009 | Miele Novotronic T240 Electric Dryer
Fuse made a loud bang. Put in new 13a fuse and
Probably the wires inside melted together and now as shor circuit occurs it causes the fuse to blow. remove the bottom of the kettle and check the wiring. There's no rocket science, so you'll identify the problem after visual inspection.
Best of luck
Aug 07, 2009 | Tefal Elegance Brushed Chrome Cordless...
Won't switch on
yes it could be a fuse but moust of the time
the fuse is blowing because power suger/or bad flyback/hozoutput/or power supply whent bad. unplug the tv .take off the back and look for the fuse you see the power cord it by the powercord if the fuse is black it a hard blow.
if you can see thur it .it a sofe blow you can try to chang it.6.1amp fuse125v or it could be 250v fuse6.1amp and if the fuse blow agon you have a short powersupply
Jun 02, 2009 | Televison & Video
Loud Bang and Projector no londger works
If the internal fuse has blown, if you connect the power lead loosely and move it about, you should not be able to hear any crackling sound of electricity. If you do then it is more likely something else other that the internal fuse. Generally, a loud bang is either the fuse or lamp.
Sep 25, 2008 | 3M MP 8749 Multimedia Projector
LG LFC23760ST Side by Side Bottom Freezer French Door Refrigerator Logo
64 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
