Question about LG Art Cool LA181CNW Split System Air Conditioner
I have a LG Artcool LAN121HNP the unit will only ciculate air (not cool) it is only 2 years old. I have had an HVAC guy look at it, he says the compressor is fine. We have put a new board in the outside unit but it will only cool when the test button on the board is pressed. He says he is not getting any signal from the inside unit, but when I switch the romote unit off the fans (both inside and outside) switch off. Could the board on the inside unit be bad.?
  • 674 Answers
Make sure none of the thermostat wires from the inside unit to the outside unit have come loose or have be cut by a weed eater or such. These units are a little more complex than your average heat pump.
Posted on Aug 25, 2010
Capillary tubing frozen
When material has passed the filter and plugged it. If the unit is less than 20 years old it may be another problem like a txv bulb not working or low on charge.
Jan 28, 2014 | LG Heating & Cooling
What does CH 24 mean on ArtCool mini-split?
Ch24 means your unit has a low or high pressure fault,check gas charge and if filters are clean see if helps
Aug 31, 2011 | LG Art Cool LA121CNP wall/window Air...
LG Artcool about 4 yrs old error code CH 05. no heating or cooling. cheers.
CH 5 on these machines indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assy to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts stockist.
Jun 16, 2011 | Heating & Cooling
LG Artcool Error Code C1. What does this mean? (Background info A/C unit works fine, cools as normal. Installed 2 years ago)
Indoor unit return air sensor fault, Open or Short. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace sensor.
Nov 08, 2010 | LG LA185HV Split System Air Conditioner
Installed an artcool in my appartment and it constanly leaves a little puddle of water on the floor, irregardless of the temp setting or the fan speed. Drain hose is connected to the plumbing drain. Water...
first of all check the outdoor unit if it is in your reach  than simply touch both the valve & feel the temp if smaller valve is colder than the bigger one than surely the problem is with refrigerant quantity.
Jul 20, 2010 | LG Art Cool LA1000PR Air Conditioner
My Artcool a/c internal unit began dripping alot of water after being used for 4 hours.... any ideas?
rochelle2511
I have an LG artcool unit too, with the same water problem. Have you found a solution?
Brad
b.emberton@comcast.net
Feb 12, 2010 | LG Heating & Cooling
Lg artcool 12000btu mirror model
1.check remore battery.if week change it
2.check indoor unit sensar of remote.
3.check sirkit board.
Mar 09, 2008 | LG Art Cool LA1000PR Air Conditioner
LG Art Cool LA181CNW Split System Air Conditioner Logo
201 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
