Question about MidiLand MLi 691PA Computer Speakers
I have a pair of MLi 691PA speakers that use a power adapter. I want to know the input voltage and if it's positive or negative tip. Thanks.
SOURCE: Lost ac power supply adaptor for Mli 190 speakers
http://an-labs.com/multi/sw190.html 12vac
Posted on Jan 22, 2007
  • 84 Answers
SOURCE: LCW-0120 Labtec speaker polarity
I am assuming that you already know which wires go to which speaker and all you need to know is which one is negative and which one is positive. Here is one way to find out. If you can access the speakers at all or at least see the cones, it will be easy.
Take a small 1.5v battery and connect it to the wires in question, connect one end to the positive(+) and the other to the negative (-) side of the battery, don't do it for a long time, just enough to observe movement on the speaker cones. Observe the cones of the speakers, if the cones get pushed or moves out, take note of the polarity of the battery because now you know which is which. Now if the cones, move inward or it gets sucked in when you apply voltage, then it's backwards.
Posted on Feb 11, 2008
SOURCE: Altec Lansing computer speakers model AVS500
18VDC 1000mA Center Positive.
Altec-Lansing
Part Number: AVS500-A6860
Model Number: 9701-00648-1UND
Posted on Nov 17, 2008
lil_smurf
  • 7 Answers
SOURCE: JBL Media 100 Speaker power?
Buy a power adapter from radio shack or similar place. You need a 1000mA 12 volt dapter. Just make sure it is rated @ or above 1000mA to avoid the adapter heating up and possibly burning. The whole setup is rated @ 850mA wich 1A(1000mA) should handle with enough head room. But it might run you about $15-20. I would just buy a cheap radio with rca inputs/aux input and use that. I got one from Walmart for around $40 and it plays CD's & AM/FM.
Posted on Jun 09, 2009
SOURCE: adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Posted on Jan 14, 2010
Hello, can someone help me, i want to know how to connect the wires if i want to use 2 channel instead of 4. THANKS IN ADVANCE!!!!!!!!!!!!!!
In order to bridge an amp, you will connect the positive lead of a speaker to one positive input on the amp, and instead of connecting the negative lead to the negative input next to the positive input you just connected, connect it to the negative input on the neighboring +/- pair. For a 4 channel amp, there should be 4 +/- pairs. you will treat 2 of these pairs as one channel, and the other 2 pairs as the other channel. Do the process described above for the other speaker as well. Here is a link with helpful pictures: http://www.ehow.com/how_5305710_bridge-channel-amp.html
Mar 07, 2011 | Koiiler 8686-C Car Audio Amplifier
The speakers will turn on but no sound will come out.
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 20, 2010 | MidiLand MLi 691PA Computer Speakers
What voltage and polarity do the ACS-5 speakers require?
Computers always use DC voltage. Computer speakers receive DC voltage from the computer.
DC voltage has a Positive and Negative polarity.
In the power jack of the speaker, the Center pin is the Positive connection. The outer shell is the Negative connection.
Center hole of the DC adapter plug - Positive.
Outer shell of the DC adapter plug - Negative
Voltage 5 Volts DC.
In case you need it,
http://support.dell.com/support/edocs/dta/acs5/
Nov 29, 2010 | Computers & Internet
JUSTER DC-691PA SPEAKERS USE AN AC WALL ADAPTER. DO YOU KNOW THE POWER REQUIRMENTS FOR THIS SYSTEM?
Computer Speakers Juster (External, Powered), (Adapter, 9V, -Outer, +Center) JusterDC-691PAYZNJ891701998
Aug 30, 2010 | Audio Players & Recorders
Just wondering what the power supply output JBL Media 3 Speakers
I have a pair of Media 3 JBL computer speakers. I am using a generic 12V DC adapter rated at 1000mA with a positive tip polarity, and it works fine.
Aug 15, 2009 | JBL Audio Players & Recorders
AVS 500 subwoofer speaker
If you have a digital tester just select DC voltage then connect the positive leads of the digital tester to any of the wire coming out of the 18V adapter (WARNING do not connect to the wire connected to the main) and then the other lead of the digital tester which is the negative connected to the other wire of the 18V adaptor. If in the screen of the digital adapter reads a negative value, then it indicates that the other wire is the negative and the other is positive. Otherwise if the tester reads a positive value then your tester's leads have got the right connection.
P.S. please rate me.
Jun 10, 2008 | Altec Lansing AVS 500 Computer Speakers
Speaker power supply
Found power supply for MLI-691 H speakers
Output is 9vdc, 600 ma. center of plug +.
SUN 9
Jun 10, 2007 | MidiLand MLi 691H Computer Speakers
MidiLand MLi 691PA Computer Speakers Logo
236 people viewed this question
Top MidiLand Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MidiLand Audio Player and Recorder Expert? Answer questions, earn points and help others
