Question about General Electric WSSH300G Front Load Washer
GE WSSH300G1WW With the door open it will start beeping, and front panel lights will light up. Have to unplug it to get lights and beeping to go off, about a week later it starts all over..
SOURCE: GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Posted on May 07, 2009
SOURCE: ge wssh300 will not start may, just beeps
hold the start and select button in for about 30 seconds together until you hear a beep; this resets the control panel
Posted on Sep 06, 2009
  • 1531 Answers
SOURCE: GE front load washer- error msg "door locked"
have you checked for any foreign objects in the drain pump itself this if the most likely problem.or the drain pump has completly stop.make sure you pull the drain hoses from the pump and check for foreign objects if there is still water in the unit use a shop vac and connect it to the drain hose to remove all the water before disconnecting the drain hoses. after the water is drain this may unlock the door as well
Posted on Sep 17, 2009
kevin_getz
  • 1031 Answers
SOURCE: i have a ge washer model#wssh300g1ww. there is
You either have a bound up (frozen) drain pump, or knowing GE's reputation with washers, the transmission (gearcase) just dug it's own grave. How old is it? Depending on the age, it might have a frozen pulley.
Posted on Dec 16, 2009
SOURCE: THe door hinge on my
I have the same washer & its 3 years old today. Rusted hinges & door & screws too.
Door is really hard to shut so I called GE to complain & they are overnighting me a new door, hinges, & screws. You should call!!
Posted on Sep 30, 2011
GE Quiet Power 3 won't start when door is closed.
What is the exact model number? This may be an issue with the cables that connect the door to the power supply.
Apr 06, 2018 | GE Dishwashers
GFWH1200DWW GE front load washer won't unlock red lock showing
From an article I found online:
See if manually opening the door will reset everything. Unplug the washer and remove the lower front panel like you're going to clean out the drain catch. Once you remove this panel you can reach up behind the upper front panel and pull down on the small plastic pull tab attached to the bottom of the door lock assembly. This will manually unlock the door so you can open the door.
Now once you have the door open, plug the washer back in and see if you can start another cycle.
Mar 06, 2016 | GE Washing Machines
The door lock isn't engaging.
you may have bent thr hing on the door if you lean on them on top they will bend try a little lift on the door then close
Sep 11, 2009 | GE WSXH208A Front Load Washer
Ge wssh300 will not start may, just beeps
Aug 04, 2009 | General Electric WSSH300G Front Load...
GE GLD5560 won't start
Although this post is old, I will help anyone else that is searching for the answer. I too had this problem but after looking at the schematics for this dishwasher, I could see where the problem was.
First, open the door and remove the eight screws that hold the inside cover to the front door on. BE CAREFUL. There are wires attached from the front panel of the door to the inside panel for the soap dispenser. Close the inside panel by slowly raising it up into its closed position and locking into place. Looking at the front panel from the inside, there is a black box at the top with a white PLASTIC PIN. This pin activates the "CLOSED" signal to the control unit. Push and HOLD the white pin DOWN until the system resets. If this does not work, you may need a new unit which runs about $6. After reseting the system, raise the front panel slightly and press and hold RESET/START for 5-6 secs. Now, with a second person holding the inner liner against the machine tightly, I started a cycle and it worked fine. Unlock the inner panel and slowly lower back down and replace the 8 screws.
It's really very simple 10 min fix. the reason this happens is due to the flawed design of the SWITCH PIN, which is not rigid enough. It tends to move side to side and become stuck. A better quality PIN assembly would solve this issue for GE forever.
Have fun.
Apr 22, 2009 | GE 24 in. GLD5560LSS Stainless Steel...
Nov 12, 2008 | GE WBVH6240F Front Load Washer
General Electric WSSH300G Front Load Washer Logo
221 people viewed this question
Top General Electric Washing Machines Experts
Sal De
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
