Question about White Sewing 4042 Mechanical Sewing Machine
I am missing the power cord and pedal for my white 4042 also maybe spool pin, where can i find replacements?
  • 340 Answers
There is one available here for $24.99.
http://www.sewingstyle.com/White-Sewing-Foot-Control.html
They do other parts for White machines too.
Posted on Aug 25, 2010
I have a brother xl5012 and would like to change the spool pin..not sure if its broken? the one on top is silver and the spare is plastic..not sure what to do..the manual has no answers.. thank you
On most machines, the spool pin simply screws into a threaded hole. If it was welded on or attached in some other permanent way, changing it may need a service visit. Brother has one of the very best service departments of any company I know. But try to unscrew the old one.. it might be stuck, a drop of penetrating oil, or maybe some pliers, might assist. If it comes out, a new one should screw in easily enough, so long as it matches the size of the hole and the threading.
Nov 17, 2014 | Sewing Machines
How to set up
  • Remove your Janome sewing machine from the box, placing the main machine on a hard surface appropriate for sewing and the accessories and smaller items to the side. Unwrap all of the wrapped items. Remove the tape used to protect the machine during shipment. Set aside the power cord and foot pedal.
  • 2
    Attach the power cord to the machine. The power cord plug-in area is located on the lower right side of all Janome sewing machines and has a series of metal prongs and a power switch. Fit the female end of the power cord onto the metal prongs and push it gently until it no longer moves.
  • 3
    Attach the foot pedal to the machine. The foot pedal plug-in is also located on the lower right side of all Janome machines, right next to the power cord plug-in. Press the foot pedal plug-in into place gently until it no longer moves.
  • 4
    Turn the power switch on. The power switch is located in the same area as the foot pedal and power cord plug-ins and is a rectangular black switch. Press this button. The sewing machine light will turn on.
  • 5
    Place a spool of thread on the spool pin, located on the upper right top side of the sewing machine. Place the thread so that the thread unwinds in a counterclockwise motion, with the thread coming off the back of the spool.
  • 6
    Insert a needle into your machine. Consult your owner's manual for the appropriate size and type of needle. Turn the needle clamp screw, located above the needle area, toward you to loosen it. Turn the needle so that the flat part of the upper shaft area faces the rear and slide the shaft of the needle up and into the needle area. Turn the needle clamp screw away from you to tighten the needle and lock it into place.
  • 7
    Wind the bobbin and insert the bobbin into the bobbin case. This procedure may vary depending on the model of your Janome machine, so consult your owner's manual for specific instructions.
  • 8
    Thread your machine according to the directions in your owner's manual. Like the bobbin, this procedure can vary widely depending on the model of your Janome machine.
  • 9
    Set your tension, located on the front of the machine, to halfway between three and four. The tension may be a dial or it may be computerized and located on the LCD screen, depending on your model. Consult your owner's manual to find out how to set the tension.
  • 10
    Place a piece of scrap fabric in the machine and sew a test seam before you start to work on a project to make sure all of your settings are correct.
    Things You'll Need
    • Janome sewing machine
    • Owner's manual
    • Needles
    • Thread
    • Bobbin
Jan 11, 2012 | Janome Sewing Machines
How to wind bobbin on white 1418
1 Release the stop-motion knob on the right side of the sewing machine by turning it oward you.2 Place a spool of thread of your choice on the spool pin located toward the back of the sewing machine.3 Pull thread from the spool through the threading knob on the top of the machine.4 Pull 2 to 3 inches of thread through one of the holes on the bobbin. Hand-wrap thread around the bobbin in an anti-clockwise direction five or six times.5 Place the wrapped bobbin on the bobbin spindle.6 Push the winder spindle to the right, against the stopper, and depress the foot pedal to begin winding.7 Wind bobbin until completed, then return winder spindle to its original position.8 Tighten the stop-motion knob.
Oct 14, 2011 | White Sewing 1418 Mechanical Sewing...
Need a user's manual for a White 4042. Is there a
Here's a free copy to download. You have to prove you're human by typing a few letters displayed and then click "View Manual". It's not the best looking - but it is readable. You may find others that are better by googling the model. This one covers models 4040, 4041 & 4042.
Please rate this reply. Thanks!
May 06, 2011 | White Sewing 4042 Mechanical Sewing...
I have a Nelco sewing machine. When I check it where the spool of thread goes. The rod is sruck down and i can't it up. I can't even put the spool of thread. what do I need todo?
I have no idea what Nelco model you are talking about. Many have a spool pin that are just tapped in from the top. If yours is not thenm maybe its missing. Or maybe broken off. If its a type that you just pull up to use then maybe you can grab it with a pliers and pull. But if you can't grab it then take the top cover off and tap it out. Add some oil to it.
Jul 12, 2010 | Sewing Machines
Light dims when you sew
the problem is that the cord that was replaced on it is too light for the sewing machine. some companies sell cords that are made with 18awg wire 18awg wire can only deliver enough electricity to run the motor sapping up all of the power from the light as soon as you push the pedal. you need to get a cord made by singer or rewire your cords with 16awg wire... 16awg wire is the standard wire for all vintage singer sewing machines it keeps the light nice and bright...... hope this helps
Aug 06, 2009 | Sewing Machines
Lost Spool pin and cap for QuikStitch SP-402
Welcome to FixYa. If you have a spool stand, that might work as long as you can thread the machine properly (give it a try!). When the thread is placed on the machine's spool pin, the spool cap keeps the thread in place and helps the thread unwind evenly - so if you are using a spool pin, you really do need a spool cap.
If the spool stand works, you are good to go. If you need to order replacement parts, I've provided a link the manufacturer's website. From there, you can contact customer support and find out if parts are available. If you can't order replacement parts, ask customer service if the machine is compatible with another brand. Another option would be to buy a spool pin and cap at a sewing machine dealer. Take the machine with you and and make sure the parts fit before you buy them.
Here's the link to the site I mentioned:
http://www.topinnovations.com/products/sew/SP-402/SP-402.html
Thanks for stopping by. If you have an extra minute, feel free to rate my solution. I'm eager to improve my solutions if they are not helpful. If you have further questions or would like to consult with another FixYa expert, just leave a comment and I'll do what I can to resolve your problem.
Oct 25, 2008 | Sew Pro QuickStitch SP-402 Mechanical...
White Sewing 4042 Mechanical Sewing Machine Logo
95 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
