Question about Gateway GT5654 Desktop PC
My computer won't boot, I just get a black screen that gives me two options, bios menu and something else f2 or F12
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 50 Answers
IF you cannot resume with the Operating system..try to go to Bios and set up the boot priority 1 = hard disc,
If this wont still work, your Operatiting system might be corrupted.. go to bios again and set up the boot priority 1 = cdrom.. next, try to insert the installation disc of your OS but do not install it, select option: REPAIR only.
If the cdrom would not boot, unplug the battery of the bios, then put it back again correctly. After this, boot again your cd.. Thanks..! dont forget to comment if you like my post.
Posted on Aug 26, 2010
What is the f2,f8, r f12 want work? only the Ctrl+ Alt+ del that wroks
F2 usually takes you to the BIOS setup screen, you need to hit the keys as soon as you power up.
F12 selects on a Dell instant boot menu to select booting from CD-ROM, USB, etc rather than the BIOS options.
F8 goes to safe mode start up for windows, this must be done before the windows logo comes up (ie when it is a black screen).
Control - Alt -Delete Keys together can be used any time, after windows boots as it tells it to re-boot the computer, back to start up.
Jan 30, 2015 | Computers & Internet
System won't boot up window XP
HI Joe. It's likely you have a virus. Or could be just a corrupted section of the hard drive. The F8 is what gets you to the black screen with the differnt boot options. F2 or Del button gets you in the the BIOS or start up instrutions for the PC. F 12 will get you boot device options. The F12 or F2 needs to be pressed before it ever gets to try starting windows. So when you first power on, immediately start tapping the F12 about once a second. This should bring up a menu of which items/ device, to start from. [If you get a stuck key message just clear it and continue tapping F12 or start over] I would suggest you use the windos CD and choose the CD device to boot from, then it will recognize the CD drive. You could follow the CD start up options to peform a repair of windows. If you do a repair, then you should also perform a virus scan immediately after. If after all that, you still have issues, then it's likely the hard drive itself is bad or going bad and you should look at replaceing it. Good luck.
Dec 05, 2012 | Dell Dimension 8200 PC Desktop
My computer will not boot windows xp os
Do you mean it won't pick the disc? If so, try F10 it should also give you a boot menu if you don't see press any key to boot from cd... The other option is boot into BIOS and change your boot order. CD-ROM/DVD should be the 1st option.8_28_2012_7_14_07_am.jpg
Aug 28, 2012 | IBM ThinkPad X41 Notebook
Linux mint 12 won't boot from CD
Restart your computer, press repetedly a key to enter BIOS, normally Del, go to Advanced BIOS Features probably and change to boot primarly from CD/DVD (1st Boot Device CD/DVD , or something like that), save and exit BIOS, and restart your computer with Linux Mint CD inside. Be aware that if you make wrong changes in BIOS, you could damage your computer.
Feb 18, 2012 | Acer TravelMate 4001LCi Notebook
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
How do I access the screen that shows BIOS options as I wish to upload UBUNTU 11.04 from a pendrive, so I want to make my first and possibly second BIOS options to be for the pendrive.
At boot time repeatedly pressing either, F2 , F12, or possibly Fn+F1 this is depending upon the bios wether it has been updated or upgraded. One of these should do the trick.....
May 15, 2011 | Dell Latitude CPI-A Notebook
How to put a os on my aspire computer
1. Press f12 as soon as the laptop starts up. This should give you a menu which allows you to select a temporary boot device, you'll need to select your cd/dvd drive.
2. Make sure the os disc is in there, and when it says 'press any key to boot from disc', press a key.
3. Follow on screen instructions.
If F12 doesn't bring up a boot menu, then you'll need to go into the bios. You do this by pressing F1, F2 or del usually, it varies between computers. For instance I have an iBM laptop and I have to press the thinkvantage button to interupt normal startup and then select either F1 for the bios or f12 for the boot menu. But whatever you have to press, it should tell you.
Once you're in the bios then you should be able to find an option to enable a boot menu, enable it, and once you've saved and exited the bios proceed from step 1.
If you can't find a boot menu option, then you will be able to find an option to change the boot order, you'll need to change it so that your cd/dvd drive is at the top. Once that's done save and exit, then proceed from step 2. In this case, once the os has finished installing, you may want to go back into the bios and put your hard drive back to the top of the boot order, this isn't necessary but if you don't then the laptop will give you the option of booting from cd/dvd every time, thus slowing the overall startup time.
Jan 18, 2011 | Acer Computers & Internet
How to set boot priority in bios is thinkcentre lenovo it has no option in bios
when i am enter in the lenovo bios in bios option have four option for first boot device. which i am select.
Oct 21, 2009 | Lenovo ThinkCentre® M55-8810 PC Desktop
Bios batt
if you leave it long enough does it boot ?
press F2 and go through the settings and check for something like "display boot menu" or similiar.
remember to save your settings upon exiting
Sep 20, 2008 | Toshiba Satellite M100 Notebook
Gateway GT5654 Desktop PC Logo
134 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
