I have a Matsui M22LI618 and I have my PC connected to it via a VGA cable, the computer only recognizes the TV as a Plug and Play monitor, indicating that it has no hardware compatable with the PC to recognize it e.g a driver for instance, this is stopping me from taking my resolution higher than 1280 x 768 with a top-of-the-range graphics card. I was told that all pc monitors and LCD screens with pc inputs should come with a driver disc to install on pc, is this true??!? Please help
SOURCE: Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
Posted on Oct 27, 2008
Hdik
  • 51 Answers
SOURCE: I have an Emachine W3650
may be your graphic driver is not installed.install graphic driver from your graphic card or motherboard driver cd.
Posted on Dec 05, 2008
Nic61
  • 1073 Answers
SOURCE: Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Posted on Dec 11, 2008
  • 38 Answers
SOURCE: How do i use my tv as my pc monitor. so i can watch movies from my computer ?
The problem may be the resolution. Your TV will run 1920x1080. You might try changing the resolution to that and then try connecting to TV again.
Posted on Jan 31, 2009
  • 27 Answers
SOURCE: nvidia geforce9400gt monitor problem
Usually the problem with windows 7. if you have 2cables connecting from youre monitor to the graphics card, unplug one of them, it worked for another guy
Posted on May 27, 2009
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
www.tomsguide.com/answers/id-1891563/connecting-vga.html
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from www.cnet.com
My custom built PC will not connect to my TV via VGA cable ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Jan 31, 2016 | VIA Computers & Internet
Connect toshiba nb500 netbook to RCA tv win 7 stater with VGA cable and s video no displaying in the monitor tv didn't recognize
Does you notebook shows any connection information after connect to tv. If not you need to install. If this didn't work you have to change VGA cable. If not your notebook doesnot supports the tv
Jan 21, 2013 | Computers & Internet
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
My pc wont recognise my tv as a second monitor - conected with VGA cable
the video card you used have a capability for dual monitor..so 1st thing that you need to do is to make sure that the computer recognized the 2nd monitor and activate dual monitor capability on the nvidia panel..after that on your tv select the proper source(like VGA, HDMI1 etc.) on which you'll be able to see the the video from the computer to your TV..
Jan 31, 2012 | Dell Computers & Internet
I Want to Play TV programs Through laptop to TV
Most late model TV can be use as a Computer monitor either via a Computer VGA input of via a HDMA input (providing your laptop has HDMA support and output). You will need the appropriate VGA or HDMA cable to connect your Laptop to your TV acting as a monitor.
Sep 24, 2011 | Televison & Video
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
Acer lcd monitor attached to dell computer optiplex gx620 have windows xp professional default is plug and play won;t recognize monitor. have service pack3. in device manager under monitor only plug...
Is it attached to your computer via a VGA cable or DVI cable if it is vga then that is your problem
If your graphics card does not have DVI then you will not be able to make best use of that monitor.
Aug 20, 2009 | Computers & Internet
HP 2140 mini note does not recognize monitor.
Try pressing the Fn key and F2 key at the same time. Also make sure your tv is on the correct imput.
Jun 23, 2009 | HP Mini 2140 Notebook
Getting my Matsui TV to play sound out of the PC VGA source
you need a cable to connect the sounds from your PC to TV. you need a baby plug to RCA plug.then you have to connect the baby plug to your pc soundcard audio output to your TV sound input.
Mar 13, 2008 | Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
