Question about Beyond Micro Computers & Internet
I have a 320gb beyond micro external hard drive. it has been working fine up to yesterday. when i turned it on it started making a wierd noise, sort of like a humming noise that has a kind of pattern to the noise. i have switched usb cord and that hasn't fixed the problem. and my computer will not read the hard drive like it is not even plugged in.
    Sergeant:
  • 203 Answers
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismatle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Thumbs up please if it's any use to you Thank you.
Posted on Aug 25, 2010
Beyond Micro BMMDU2 wont show up on my laptop
might need to reset by turning both off
keep power for ext drive OFF
turn computer on
plug in ext drive usb(no power on drive)
turn ext drive power on
see if windows can ''see'' it now?
May 14, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
I have a 250 gb beyond micro hardrive, it has always worked great until i brought it overseas with me. The first time i tried to plug it in it didn't recogognize the usb, it also sort of freezes my...
Press recognized Key (Del Key, F1 or someone other indicatessystems while booting).Enter BIOS Setup enable the option for plug and play,also enable USB option enable, save setting and exit from BIOB, it willrestarts and you will be done INSHALLAH.
Sep 23, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Beyond Micro BMMDU2 250 GB external hard drive not working
It is highly unlikely that it will work. A circuit board from the same make and model hard drive would be a better choice, but I think a fire damaged hard drive would not work with a functioning circuit board. It depends upon how much heat the hard drive was subject to.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their services. Depending upon how valuable your data is, I suggest you get a quote first.
Apr 01, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Its not getting recognized...though it used it before
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
Best regards
Jan 08, 2010 | Western Digital Passport 320GB External...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
I/O Magic 320GB external hard drive making clicking noise
it happens when the hard is gone bad or can`t be recognised.you can try uninstalling the drive from device manager.you can check the hard drive case or can try the hard drive on some other computer.
Jul 08, 2009 | Computers & Internet
External Hard Drive - Beyond Micro
I have the same BMMDU2. It's used 12V/1.5A power suply.
May 11, 2009 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
I require a driver for our Beyond micro external hard drive.
It looks as though there is no driver support for beyond micro although the specs state that the drive is plug and play. which means you just plug it in and windows sets it up. other than that there are no software or drivers for it.
best of luck.
hope this helped.
please remember to rate me.
Mar 02, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Red dot and beep
The problem is in most cases the Power Supply given is of too low of Wattage, at 1.5. After some time, it will no longer provide the drive the needed power, thus the red light.
Try another similar power supply of higher Watts (my Maxtor has it at 2.0 watts.
Try getting Higher power Supply from Radio Shack. Store Tech will Help you.
Lastly, inside the enclosure is simply a typical Hard Drive. Remove it and Slave it to your PC.
Jul 06, 2008 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Computers & Internet Logo
155 people viewed this question
Top Beyond Micro Computers & Internet Experts
David Payne
David Payne
Are you a Beyond Micro Computer and Internet Expert? Answer questions, earn points and help others
