Our Lasko fan is a year old type wta, TP120 volt AC 60 Hz 0.38 amps Has been working all summer, went to turn it on a couple weeks ago and didn't work. Father took it apart to see if a wire lose or motor burnt out and was getting noise from motor and no lose wires, he is stumped. What do you suggest?
  • 116 Answers
SOURCE: My ac fan went out on a carrier ac unit. Need wiring help
use a seperate capicitor for the fan only pick up 1 leg of power from common side of the compressor cap and the other from the contactor or the board in a heat pump situation
Posted on May 11, 2009
  • 30 Answers
SOURCE: need to connect 240 volt 60 amp breaker with 6.3 - 4 wire
Yes the red and black wires are both hot. As for the white and bare wire, they can both go on the neutral bus bar because ground and neutral are not separated. Actually you don't have to have the bare ground wire, but it is a good idea to connect it for inspection and code purposes. If you don't have a neutral bar in the subpanel, you can just connect the white and bare wires directly to the box and they will be ok.
Posted on Aug 13, 2009
  • 94 Answers
SOURCE: a few minutes ago I described the problem with our
It would be cheaper to purchase a new ceiling fan. Sorry.
Posted on Aug 22, 2009
shastalaker7
  • 1515 Answers
SOURCE: We require condenser fan motors for Interclisa
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Posted on Jan 22, 2010
icemelts
  • 246 Answers
SOURCE: We have a Weatherking Heater/AC unit the heater
I think you have a definite short and it's in the 24 volt circuit. The only problem is - 'finding a low voltage short' is not the easiest thing in the world to do - so - I would guess you'd need a Service Tech.
good luck!
Posted on Jun 29, 2010
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    Trying to find the right fuse for a eden World Tour 800 bass amp
    Well, hope this helps you.
    Fuse Requirements:
    USA @ 120 Volts /60 HZ - 10 Amps, 5 x 20 mm GMC/T/slow blow
    Europe @ 240 Volts/50 Hz - 5 Amps, 5 x 20 mm GMC/T/slow blow
    Japan @ 100 Volts/60 Hz - 12 Amps, 5 x 20 mm GMC/T/slow blow
    Mar 10, 2013 | Hartke HyDrive HX410 4x10 Bass Cabinet...
    What should i set the micro switch on the back at?
    Power:
    2 ohm stereo (per channel): 975W
    4 ohm stereo (per channel): 660W
    8 ohm stereo (per channel): 400W
    4 ohm bridge-mono: 1950W
    8 ohm bridge-mono: 1320W
    Load Impedance: Safe with all types of loads. Rated for 4 and 8 ohms in Stereo mode, 4 ohms in Bridge-Mono mode
    Voltage Gain to 1-kHz, 8-ohm rated output,
    CE 1000:
    30.5-dB gain at 1.4-volt sensitivity;
    26-dB gain at 2.34-volt sensitivity.
    CE 2000:
    32.1-dB gain at 1.4-volt sensitivity;
    26-dB gain at 2.83-volt sensitivity.
    Required AC Mains: 50/60 Hz (North American units are 60 Hz only); 100, 120 and 230-240 VAC (+/-10%) units are available.
    AC Line Current,
    100 Volts: 11.4 A;
    120 Volts: 9.5 A;
    230-240 Volts: 5.0 A;
    At Idle: All amps draw no more than 90 watts.
    AC Line Connector: NEMA 5-15P (15 A).
    Sep 07, 2012 | Crown CE2000 2-Channel Amplifier
    I have an old zenith is4070. I am trying to figure out how many watts it pushes out to my speakers.
    Model # IS 4070
    AM/FM Stereo Receiver
    With Phonograph and Cassette Play/Record
    Serial # W288209
    Power Source AC 120 V 60 Hz
    78 Watts 0.65 Amps
    Unswitched
    AC 120V 60 Hz
    200 W Max
    Jul 09, 2011 | Zenith Audio Players & Recorders
    Heat/AC unit in working order, plugged in 20Amp outlet.. no fan?
    Hi1
    Do you have at least 200 volts at your outlet? Check that first. You said you brought it home from work, so when you plugged it in at home did you plug it into a 120 volt recepticle?
    Jan 01, 2010 | Emerson Quiet Kool 12NW46HK Air...
    Lasko Box Fan Stinks!
    same thing with my lasko box fan awful oil smell
    Aug 05, 2009 | Lasko 3720 Floor / Box Fan
    SR573... Does it support NTSC/PAL?.
    There's no mention of either NTSC or PAL in any spec sheet.
    This link leads to Onkyo and the rear view of the amp lacks the voltage selector.
    http://www.onkyousa.com/model.cfm?m=TX-SR573&class=Receiver&p=s
    The manual for the similar model SR575 says the North American model does not have the voltage selector. Too bad. Under the general specs for the variants of this family of receivers they list the following power specs. I have no idea where you have to go to buy one from the "Others" group.
    Power Supply North American: AC 120 V, 60 Hz
    European: AC 230 V, 50 Hz
    Others: AC 120/220-240 V, 50/60 Hz
    AC 220 V, 50/60 Hz
    Some aliases for the SR575=
    TX-SR505
    TX-SR505E
    TX-SR8550
    TX-SR575
    You could do what I did over 30 years ago. Join the Army, go overseas and buy one in the PX. Every HiFi product we bought in the PX in the 70's had the dual voltage feature.
    Apr 07, 2009 | Onkyo TX-SR573 Receiver
    Refrigerator energy consumption
    power usage is 270 watts but how much is used in year depends on its cycle time which in turn is dependant on weather etc. there isn't a simple answer
    Sep 02, 2008 | Refrigerators
    A/c fan doesn't work on Jeep Grand Cherokee
    your fan motor needs to be replaced chances are it doesn't spin free and due to a sudden vibration it will work on it's own. when you have this replaced i would also change the reostat.
    Aug 18, 2008 | 1998 Jeep Grand Cherokee
    Heating & Cooling Logo
    120 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Donni Steen
